some new best at local1/8 mile test/tune
#710265
05/28/10 10:49 PM
05/28/10 10:49 PM
Posts: 1,365 elmira ny
hp340nos
elmira ny
i drive the truck to the track which is about 35 minutes .i got a new best 60ft of 1.63, before this best was 1.69 and a e.t. of 7.53, best ever et before was a 7.55 et at out local 1/8mile track,vehicle is 3360#,street /strip, 88 dakota 9.3.1comp, 318 all stock bottom end with ported 302 casting heads and comp .454 lift cam ,edelbrock performer intake holley 650 db pumper.727 trans with 3500 stall ptc converter,3.91 8 3/4 rear,tires are m/t street radials 295/65-15.i run a clean nitrous tune-up of 175 hp on this motor.i drive it to the track pull timing back to 24* and spray it,tire pressure was at 27 psi,its my 1st time on this big of a tire so i left the air pressure high,i will play with tire psi next time out.it really hooked hard and surprised me on that run. i cant wait until the 418 small block stroker is done.
Re: 383man
[Re: cheapstreetdustr]
#710276
05/31/10 03:05 PM
05/31/10 03:05 PM
hp340nos
elmira ny
thanks,it runs 8.9-9.0@76mph on motor in the 1/8,jets are.071n/.063 fuel.timing pulled back to 24*total,plug gap set at .030.i got the tune-up from monte smith.
