Page 3 of 3 1 2 3
Re: 1970 Challenger electrical gremlins [Re: HealthServices] #708944
11/02/11 04:14 PM
11/02/11 04:14 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
or...
a diode was not installed on the reproduction harness causing it to back feed power!
Allen, I suspect that this is the correct answer!
The under dash on this car is tight quarters as it had AC on it, and I haven't laid eyes on the buzzer yet.
Mark
http://marsh-racing.com/Mark%20Mahorney-Allstate.htm
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: 1970 Challenger electrical gremlins [Re: HealthServices] #708945
11/02/11 04:49 PM
11/02/11 04:49 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hello, HealthServices helped me BIG time on my issue. I don't have that diode either. The reproduction harnesses must not use it. Everything else works fine on mine since I removed the relay. My trouble was actually the opposite or yours. Mine would run as long as the door was open. I could care less about the buzzer, so I just left it out. Worked fine since. Jeff
Page 3 of 3 1 2 3
