Which aluminum heads
#708694
05/26/10 08:50 PM
05/26/10 08:50 PM
Posts: 1,630 North Central Florida
eightlitermopar
I have only messed with 40 year old iron heads. So, if I was building a stout 440, 9.5 - 10.1 compression Comp XE 274 OR Comp XE 275 HL cam with TTI headers. Speed demon carb. Edelbrock performer RPM intake. Which head is the choice head, right out of the box (checked by machinist before assembly of course). From your experience, why or why not? I have heard the edelbrock RPM heads are great for the mopar engines....but.... you tell me! #1 Edelbrock Performer RPM #2 440 source stealth heads #3 Indy 440 SR heads eight
Mopar or no car
Re: Which aluminum heads
[Re: ireland383]
#708704
05/27/10 09:40 AM
05/27/10 09:40 AM
Posts: 21,064 Niles , Ohio
therocks
Niles , Ohio
I have the Stealths also.Going on the 3rd year and no problems.I did change the sprimgs, locks, and retainers as I run a .588 lift and solids with a 4 speed and hit some high revs.My pushrods cleared just barely.I was thinking of the Eddys but the angled plugs were a problem with my dome pistons.Just what ever you buy have a good machine shop check them.Rocky
Chrysler Firepower
[Re: eightlitermopar]
#708706
05/27/10 10:26 PM
05/27/10 10:26 PM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have the Indy EZ's with a Performer RPM intake and Doug's headers with no issues with header fit and my hood closes with a 3" element and drop base air cleaner. I think the EZ's would be the best choice with room to grow when you get used to that level of HP Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#708707
05/27/10 11:39 PM
05/27/10 11:39 PM
eightlitermopar
Wow, thanks for the replies guys.... My brother just finished his 493 stroker motor and it is scarey fast compared the stock, low compression 440 we had in it before... it has cnc ported edelbrocks..... For my future build I have had my eyes opened as I have a lot more options now. I never even heard much about the mopar 452 heads, I'll have to look into a set of those for my 383 in my 71 roadrunner, then I wouldn't have to change out the headers! Anyway...any more input let me know! As always...learning a lot here. eight
Mopar or no car
#708708
05/28/10 06:03 PM
05/28/10 06:03 PM
eightlitermopar
Ok, for those of you who have had 440 source heads AND edelbrock heads.... why do the edelbrock heads win that contest? Noticable performance difference Crappy castings? Other sorts of quality....? eight
Mopar or no car
#708709
05/28/10 06:48 PM
05/28/10 06:48 PM
Challenger 1
Cincinnati, Ohio
eight
AMERICAN MADE for one, probaly the biggest thing for me.
[Re: Challenger 1]
#708710
05/28/10 07:38 PM
05/28/10 07:38 PM
Posts: 5,948 British Columbia
chrisf
British Columbia
having had both and still owning 440 source ones i can answer that. my source heads were the first generation. they needed locks and retainers out of the box as they were poor quality. emailed brandon and never even got a response (you will soon see a pattern here). no biggie. bolted them on my 383 while i was building my new 383. pulled them and took them to dodgefarmer (randy) to check out how they were holding up after 5000miles before i bolted them to my new 383. apparently they had huge amounts of porosity around the water jacket areas. Randy fixed them up (again) and was back in business. emailed brandon again. ignored. send him another, ignored. sent him a final one saying thanks for nothing and the problem was fixed. nothing. He then emails and says he doesnt consider it a problem unless i phone and since the problem was fixed he didnt feel he needed to talk to me. my final email was to brandon sugesting some places he could "store" his parts on his person. if i was selling a product that was poor quality i would want to know what caused the problem. he obvously knew about the problem or didnt care as they were selling well anyways. ride the train until it falls off the tracks i guess i have probably around $1600 into these heads right now. I bought them for the sole reason to save a couple dollars. in the long run i could have bought eddies and never had any problems. i have posted of this issue here before and electrolisis may have been a issue. IF thats the case why didnt my eddy heads do the same thing? cheap castings on the source stuff thanks brandon i hope my post brings in some business for you
[Re: chrisf]
#708711
05/28/10 08:25 PM
05/28/10 08:25 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I opted for the source heads mostly because of the stock external appearance. The fact that they offer an on par performance with Eddys for about $500 less also factored in.
[Re: MIKES_DUSTER]
#708713
05/29/10 06:27 PM
05/29/10 06:27 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Im not and have never been a fan of the Source stuff. With the increasing numbers of cracked Source heads, Eddys or the MP 452 heads are the only way Id go. Plus the Eddys/452s flow a little more than the Source heads, un ported.
Basically the hardware with the Source heads is useless with any cam..............not mention my experience with a few of their other parts.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
