help! 98 dakota trans #70793
06/10/08 07:32 AM
06/10/08 07:32 AM
greenfield, ind.
P
PLMCRZY Offline OP
PLMCRZY  Offline OP
P
greenfield, ind.
help! after driving my dakota through some deep water my check engine light came on. checked it with my obd2 and i get code 1762. gov press sensor offset. does anyone know what this means? thanks, dennis
Re: help! 98 dakota trans [Re: PLMCRZY] #70794
06/10/08 12:51 PM
06/10/08 12:51 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
The sensor wires may have got wet or pulled loose and threw a false code. If you were in water above the axles for a while you should check all the fluids/wire connecters for water damage.
