instructions for breaking in a new cam in a 340 #707831
05/25/10 10:50 PM
05/25/10 10:50 PM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
I bought new in the box mopar purple cam from a guy but there were no instructions.
It is a hydraulic lifter setup
From startup of he motor what should be the rpms and for how long
I have read articles that say to vary the rpms between 2000--3000 for 30 minutes
Some guys say to run it for 10 minutes let it cool and then another 10 minutes.
Could I get some suggestions.
Re: instructions for breaking in a new cam in a 340 [Re: Dart6pak] #707832
05/25/10 11:08 PM
05/25/10 11:08 PM
Az
Crizila Offline
Crizila  Offline
Az
Anything over 2K for about 20 minutes will do it. Don't forget to use some zinc additive for break-in purposes. Assume you installed it with cam lube and checked the lifters for free travel in their respective lifter bores?
Fastest 300
Re: instructions for breaking in a new cam in a 340 [Re: Crizila] #707833
05/25/10 11:10 PM
05/25/10 11:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The instructions with my lunati cam said to run it between 2500-3000rpm for 20 minutes, varying the rpm up/down by 200 every minute or so. Then shut off, change oil and you're good to go. I followed what they said to do and had no issues. I did add in some of the old style GM EOS to pump up the zinc level during break-in.
Re: instructions for breaking in a new cam in a 340 [Re: Dart6pak] #707834
05/26/10 12:18 AM
05/26/10 12:18 AM
~2500 rpm for 20-30 minutes. during mockup clean the lifter bores and lifters w brake kleen and lube them lightly w WD40 and raise each lifter up off it's lobe w your finger and let it go and it should fall back onto the lobe w a resounding "thunk" and if not the lifter bores need honed a bit so the lifter is free to rotate. enough zinc in the oil. Remove the inner coil springs. no thermostat. large shop fan in front of eng. Front of car jacked way up for air pockets. rap the throttle many times during the breakin and read "breakin secrets" at www.mototuneusa.com. One helper to add trans fluid when it starts (several qts before starting). One helper watching above for fuel leaks. One helper underneath watching for leaks. You in the drivers seat to gun it and shout orders. Dist snugged tight enough for another helper to turn it and man the timing light. I like to have it in gear w the rear wheels off the ground on sturdy stands to load the rings. Fill the bowls and check for AP squirt. reluctor blade aligned w the magnet slot w the marks @10BTDC #1 compression which'll fire it at 8 or 9 before. Any leaks cut it off immediately and correct and start over. I like to preoil it w the drill (and if solids adj them) THEN take the rocker assys back off then lube the lifter bottoms/lobes w the goop then install the intake/carb/rocker assys as the adj screw clearances will not change from coming off/on 1 time and I want the cam properly prepped w all the reported failures. Bottom line have all systems prepped for it to light off immediately and (have the throttle screw turned in enough to get close to 2500 rpm.
