Re: HHR elec. fans "again"?
[Re: joedust451]
#706228
05/24/10 01:04 AM
05/24/10 01:04 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I think people were getting it for 60 something at rock auto
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#706229
05/24/10 03:44 AM
05/24/10 03:44 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
the one i have is for a 2007 hhr. It takes up my entire radiator and it simply WORKS , these fans flow A LOT of air. paid $60 for it new from rock auto.
[Re: WayneM]
#706237
05/24/10 08:40 PM
05/24/10 08:40 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Installed.
How did you strap it to the radiator, & did you have to trim it down, i've got 4" from the rad. cores too the WP pulley. One other thing, what amp alt. are you useing?
[Re: joedust451]
#706238
05/24/10 09:12 PM
05/24/10 09:12 PM
Posts: 815 Alexandria, NJ
WayneM
Alexandria, NJ
The fan has hollow ribs that run up/ down. They line up perfectly with the stock shroud mount holes. I used 10/24 screws and nuts in each corner. I held the nuts with my long needlenose pliers. Needless to say, the rad and fan come out in one piece. Yes, I had to trim a lot. I took the motor out and trimmed away the back that covers the motor. Lots of trial fit. The alternator is a basic 60 amp square back.
2014 Durango R/T 2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed 1998 Dodge Durango SLT 5.2 1971 Plymouth Duster- <<<<<MOPAR SPOKEN HERE>>>>>
[Re: WayneM]
#706239
05/24/10 09:29 PM
05/24/10 09:29 PM
joedust451
super gas
super gas
Branson, Mo.
Thanks, i'll most likely get one, what was the part #?
[Re: joedust451]
#706240
05/24/10 11:24 PM
05/24/10 11:24 PM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
So how much room do you need to get it in there? I have a 16" fan from Mancini and I was looking into the HHR instead.Last Thursday it was over eighty here and my car went over 220 for a little bit until I got some fresh air in the grill. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#706241
05/25/10 12:30 AM
05/25/10 12:30 AM
joedust451
super gas
super gas
Branson, Mo.
About 3.1/2" after triming it down from what i'm seeing, there about 4", i'm sure your car has alot more room then my Dart, so it should fit fine.
[Re: joedust451]
#706244
05/25/10 11:52 AM
05/25/10 11:52 AM
Posts: 754 Longview, Texas
marvo451
Longview, Texas
The factory male plug (the one NOT on the fan housing) is on many other GM cars at the U pull it. They gave me one for nothing. The Rock Auto site will let you see the applications if you look for them. Mine came with about 4 feet of both wires and came off a 1995 Buick.
