Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: Labratt] #704900
05/23/10 09:14 AM
05/23/10 09:14 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Hi Randy, the 120mph shows 500hp @ 3750 raceweight on the Moroso speed calculator.
I'd try sealing the carb to the scoop for some fresh air.
Ron
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: firefighter3931] #704901
05/23/10 10:23 AM
05/23/10 10:23 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,fella's! Maybe I'm way off! Especially if Eddie's getting 460hp at the wheels with head work done! How much flow does the CNC work show @ .600-.650 lift? How does that translate in horsepower gain? Thanks,Eddie! Sounds like the RR's running great! With a little suspension work,sounds like a high-10-second ride! Ron,Raff got the same 500hp # I think he used the Moroso calculator,also! Thanks! RandyB
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: Labratt] #704902
05/23/10 05:24 PM
05/23/10 05:24 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Sunday evening
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: Labratt] #704903
05/23/10 05:42 PM
05/23/10 05:42 PM
Utah
topbrent Offline
topbrent  Offline
Utah
How much flow does the CNC work show @ .600-.650 lift? How does that translate in horsepower gain? ...With a little suspension work,sounds like a high-10-second ride!
Here is the flow sheet from a set of standard port window MCH CNC Edelbrock RPM heads we purchased.
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: Labratt] #704904
05/23/10 05:44 PM
05/23/10 05:44 PM
Hemiroid Offline
Hemiroid  Offline
It really will depend on how extensively ported the heads are now. If Dwayne spent a lot of time with them hand porting them, I doubt Jeff's CNC program will improve it much, if any at all. That's not a shot at Jeff's program in any way, it's just that Dwayne is a very accomplished wedge head porter and there's only so much that can be done. If the heads are just touched up, then there could be significant gains @.600-.700 lift.
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: Labratt] #704905
05/23/10 06:06 PM
05/23/10 06:06 PM
Utah
topbrent Offline
topbrent  Offline
Utah
GTX weighs 3740,race weight,and runs 11.19-11.30 @ 120mph. Motor's a '70' +.040 440 block,10:25:1 Diamond Forged pistons,OTB Eddy Performers,Comp SQ solid flat tappet with .610 lift and 260/266 @ .050 duration,105 installed centerline. M-1 intake,and 850 Holley DP. Headers are 2" TTI's, 3.5 collectors. Any estimates??? -RandyB
Randy,
In the Fall 2007 Engine Masters Magazine, Steve Dulcich dyno'ed a simple 448" motor back to back with stock RPM heads vs Modern Cylinder Head CNC RPM heads.
At 6000-rpm peak, he gained 46 HP with the swap. From 529hp to 574hp
His combo:
- Speed-Pro-2355 pistons, 10.2 compression
- Comp MM Flat tappet cam, 243°/247° @.050, .586/.597 lift, 110°LSA, 106° installed
- Comp 1.6 Roller rockers
- Victor intake
- RS1000 Demon carb
- TTI 2-2_1/8 headers.
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: topbrent] #704906
05/23/10 07:33 PM
05/23/10 07:33 PM
Hemiroid Offline
Hemiroid  Offline
Randy,
His combo:
- Victor intake
- RS1000 Demon carb
I guess I missed the "OOTB" comment the first time I read it. As Topbrent mentioned, there's lots to be gained from Jeff's CNC porting over the OOTB heads.
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: Hemiroid] #704907
05/24/10 12:09 AM
05/24/10 12:09 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for your info,Brent! 322cfm @ .600 lift ain't too shabby! Aren't they only around 280-285 OTB??? Definately enough to support 650 hp,after porting! I would think high 10's would be attainable if I had them done. Thanks for your input Marc! Hope to see you at the track this summer! RandyB
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: Labratt] #704908
05/24/10 11:30 AM
05/24/10 11:30 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good luck over there at Jake's Randy.
I've been at 3 different chassis dyno facilities in the area so far, and Jakes is the best to date.
It should be good to compare notes too...although it's been several years since I've been, I still have the paperwork.
Rich H.
Esse Quam Videri
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: ZIPPY] #704909
05/24/10 11:45 AM
05/24/10 11:45 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Rich,can't get much closer performance-wise than our X's! Could you(if you have time)post some of your #'s? I'm VERY curious! THANKS IN ADVANCE! RandyB
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: Labratt] #704910
05/24/10 12:11 PM
05/24/10 12:11 PM
tboomer Offline
tboomer  Offline
Good luck,Randy...I think you would be a 10.96 with improved head flow....How about 1.6 rockers??
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: tboomer] #704911
05/24/10 12:40 PM
05/24/10 12:40 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Teddy,I'm currently running Crane ductile in a 1.6 ratio,giving me approx. .615I and .620E w 260/266@ .050 duration. I'm almost certain it'll run 10.80's-10.90's with the head work. Not so sure about raising the CR though! Supposedly have enough V/P clearance for a .650 net lift cam! Not much room to play with. Hope you get your new bullet soon,You're gonna have some FUN!!! RandyB
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: Labratt] #704912
05/24/10 08:18 PM
05/24/10 08:18 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Randy, good luck at Jakes. From the pics I've seen that car is a beauty. Let us know how it all works out. I really need to get the Dart Sport scaled and they are real close. I could even drive it there! If you are still down that way after 3pm give me a shout, I'd like to meet you and the "X"!
Randy J.
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: Dartin] #704913
05/24/10 08:22 PM
05/24/10 08:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Randy J.
I use to live 2 blocks from Jakes... over on the
Clinton River(Rivervista dr)
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: MR_P_BODY] #704914
05/24/10 08:32 PM
05/24/10 08:32 PM
Dartin Offline
Dartin  Offline
I'm at 18 Mile and Garfield. I go past there on my way to Ermas for frozen custard!
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: Dartin] #704915
05/25/10 07:01 AM
05/25/10 07:01 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Randy! Unfortunately,when I'm done at Gary's I have to head over to 23/Gratiot for physical therapy @ 3:00! We'll have to set something up in the near future! RandyB
Re: YET ANOTHER HOW MUCH DOES IT MAKE QUESTION!!! [Re: Labratt] #704916
05/25/10 09:47 AM
05/25/10 09:47 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Randy,
No problem posting some numbers.
To understand where they're coming from: At the time it ran the 11.24 in my signature, it was making 488rwhp on a "dynapack 3000" chassis dyno, which bolts to the axle flanges instead of being on tire rollers....a very weird looking setup.
Changed carb, intake, headers, exhaust....and was ready for another test but the dynapack guy told me not to come back again (he mainly works with import tuner cars with stick shifts, and he didn't like the torque the high stall converter/big ci combo put into his dyno.....There was a flashing red light on the display that said the torque capacity was at the limit)....So I went to Jakes Dynojet instead where it made 499 rwhp.
Never made it back to the track after that. But maybe this weekend it'll finally happen.
Rich H.
Esse Quam Videri
