It's in, running and has too high oil pressure???
#702566
05/19/10 05:42 PM
05/19/10 05:42 PM
Posts: 5,000 Tampa Florida
dc426
gotta keep'm separated
Tampa Florida
It's finally all together, in the car and running. It was actually in and fired up last week but I had a rocker adjuster break. So finally UPS dropped off the the ones and I re-fired it up. It sounds good but seems to have unusually high oil pressure. Since the episode of the windage tray piece braking off I have replaced all new bearings, rings, polished the crank, and R&R the heads. The old oil pump used to have 65 LBS hot or cold. The new one has about 75 at idle and seems to go over 100 if you rap it. I got the motor up to 160*. I'm using Rotella 15/40 in it. I'm gonna switch to a straight 30 wt. Any thoughts on this?? I have yet to get the car to the track and really put some heat in it. But, I still think that's a little high though??? DC
Re: It's in, running and has too high oil pressure???
[Re: dc426]
#702569
05/19/10 05:56 PM
05/19/10 05:56 PM
Quicktree
Melling high volume pump. Same as what was in there before.
thats probably your problem. these new hv pumps have a lot of pressure.
[Re: dc426]
#702572
05/19/10 06:06 PM
05/19/10 06:06 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I can't see that oil pressure hurting anything. Seems fine to me. I have an adjustable external deal on my B1, and just for kicks, tried back to back runs with oil pressure 75 and 100+.. There was ZERO difference in ET.. So why stress over nothing.. Chris..
[Re: Chris'sBarracuda]
#702573
05/19/10 06:47 PM
05/19/10 06:47 PM
Posts: 1,880 USA
Ron Silva
USA
I would never run straight 30 weight. I would go to 5W30 or maybe the 10W30 Valvoline racing oil and if your water temp was 160 that means nothing. The oil temp could still be way lower than that. Drive it for 30 minutes and report back.
SRT DEMON ONE SEAT
[Re: dc426]
#702575
05/19/10 07:00 PM
05/19/10 07:00 PM
Posts: 16,923 NC
440Jim
NC
Switching to straight 30 wt will make the cold pressure even higher. I would stick with the 15W-40.
Put the relief spring from the old pump in the new pump. The new pump spring is likely different.
[Re: Ron Silva]
#702576
05/19/10 07:01 PM
05/19/10 07:01 PM
Posts: 5,875 communist bloc of new jersey
jamesc
agreed, fwiw i believe the shell 15-40 is pretty decent oil. also as mentioned if the oil temp wasn't up is could contribute.
[Re: jamesc]
#702577
05/19/10 07:07 PM
05/19/10 07:07 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
Chris I just went through this myself my HV pump was pushing 80 psi cold at idle and well over 100 and the relief was not sticking as I pulled the pump apart and cleaned it. I ended up putting a standard pump in mine but before I did I put a 5w30 in it and that helped a lot ran it for a few weeks like that before I pulled and replaced the pump. I found out a standard pump will do just fine with a little clean up and it uses less HP to turn. My standard pump with 10w40 engine hot holds 40 psi at idle and almost 80 down track.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
#702578
05/19/10 07:26 PM
05/19/10 07:26 PM
Quicktree
Chris..
well having blown 3 filters apart in 2 weeks at the track during a burn out the guys get pissed in a hurry I bet Myron remembers that. I made changes to the springs every time. ended up with a stock pump and spring to solve the problem. it does matter and dangerous to boot.
[Re: dc426]
#702579
05/19/10 07:49 PM
05/19/10 07:49 PM
I didn't but when I fired it up the other day before the rocker adjuster broke it was pretty much normal. Had 75 constant.
are you saying you re-used the same pump but didn't take it apart to thoroughly clean and remove any metal that might have been trapped in it? if you did, i guess you know where that metal could end up.
please, say it ain't so...
[Re: Quicktree]
#702582
05/19/10 08:18 PM
05/19/10 08:18 PM
Chris'sBarracuda
Arizona
Chris..
System 1
Chiris..
#702583
05/19/10 08:30 PM
05/19/10 08:30 PM
Quicktree
Chris..
System 1
Chiris..
thats what we changed to after the 3rd time
#702584
05/19/10 08:37 PM
05/19/10 08:37 PM
dc426
Tampa Florida
Of course not. I bought a new Melling HV pump.
[Re: Quicktree]
#702585
05/19/10 08:45 PM
05/19/10 08:45 PM
Posts: 5,067 Orlando Florida
blown572dart
Orlando Florida
Chris..
System 1
Chiris..
CH!T Tony even I learned after the second time
I run straight 70 and have 200lbs of pressure.
Jimmy
Post deleted by Defbob
[Re: blown572dart]
#702586
05/19/10 08:58 PM
05/19/10 08:58 PM
[Re: dc426]
#702589
05/19/10 09:16 PM
05/19/10 09:16 PM
Posts: 5,987 Anoka County, MN
Leigh
Anoka County, MN
Yeah, I know. Pull the distributer to allow tilting of the engine to keep pressure off the center link that goes through the pan. Pull the headers before removing the pittman arm and tie rod ends. Of course, this is after removing the front wheels. Then, everything is done on the back, including recentering the 340/360 oil pan spacer. Plus, the pan is so big, there isn't much room between it and the trans. I'll pull the motor next time, all that is left is the converter bolts. Doing it on the engine stand is a H E L L of alot better deal. Like I said, GOOD LUCK
[Re: jamesc]
#702591
05/19/10 10:42 PM
05/19/10 10:42 PM
Leigh
Anoka County, MN
OR you could eat a slice of pizza while you pull the pump off your big block...OK maybe two slices
Isn't that the truth. So easy, even a... Naa, I ain't going there.
[Re: flatiron]
#702593
05/20/10 12:54 AM
05/20/10 12:54 AM
Posts: 1,532 off the grid
340B5
off the grid
The HV72 I put in my SB put out 80psi in March when I first started it.(45deg) Now after a couple hrs run time and a couple passes it is 62psi@2000 and 45psi at idle (1150 rpm@ 70 deg.) Oil is 10-30 Mobil 1.
Yeah, it's got a smallblock.
[Re: jamesc]
#702594
05/20/10 02:12 AM
05/20/10 02:12 AM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
HELL ...you could pull-the-pan in that RE dragster on ONE SLICE. .... SAME goes for my FED that is going together .... but my v-drive boat ?... not-so-much.
B U T ...all this heavy-weight oils you are talkin' about ..... on a race-car-only ....why aren't you thinking 0 or 10 weight stuff ?
[Re: Leigh]
#702595
05/20/10 04:48 AM
05/20/10 04:48 AM
[Re: Ron Silva]
#702597
05/20/10 09:08 AM
05/20/10 09:08 AM
Posts: 8,165 Left Coast
BobR
Left Coast
I agree. Why use heavier oil? 15/40 oil is 15 weight oil with hot properties of 40 weight. Straight 30 will result in higher pressure-especially until fully warmed.
[Re: 3ddart]
#702598
05/20/10 09:49 AM
05/20/10 09:49 AM
so how is it you guys are missing this BEFORE you drop the engine in the car? i always prime engines while on the stand so there's no surprises afterward.
[Re: BobR]
#702599
05/20/10 09:50 AM
05/20/10 09:50 AM
Posts: 100 Winnipeg, Canada
StrokerDart
Winnipeg, Canada
I had the EXACT same "runaway oil pressure" problem last season with a freshened smallbock and new Melling HV pump. First time in all these years that this has happened to me. I replaced it with another HV pump (this time it was a Speed Pro but anyways) and problem solved. BTW, the bad pump did not show any particular problem when I dissassembled it after removal (and I had opened it up/inspected it prior to original install). It had to be the relif valve but I could not prove it to myself so in went he new pump. I feel for ya on the job ahead .... I think in hindsight, pulling the motor back out would have been easier than dropping the pan in the car
#702600
05/20/10 09:53 AM
05/20/10 09:53 AM
StrokerDart
Winnipeg, Canada
In my case I had primed the engine on the stand but with just the drill speed... it looked normal so I got fooled into thinking all was well.
#702601
05/20/10 10:09 AM
05/20/10 10:09 AM
Posts: 52,972 Romeo MI
MR_P_BODY
So Dram... what would you expect to see for a pressure while priming and what size drill motor(or what ever you use).... I know on my stuff I usually see 70
[Re: BobR]
#702602
05/20/10 10:10 AM
05/20/10 10:10 AM
Posts: 2,177 ill
dennismopar73
ill
WHAT ???? YOU HAVE THAT BACKWARDS 30 is 30 10w 30 10w 40 5w30 it is a 30 w until the temp starts falling below the 32^ then it stats to act like thinner wieght for easier starts in winter i used to spec out oil for trucking companies desil oil have certain properties to help in sludge/ breakdown additives and soot control
Re: It's in, running ,has too high oil pressure**UPDATE
[Re: dennismopar73]
#702603
05/20/10 10:55 AM
05/20/10 10:55 AM
dc426
Tampa Florida
Thanks for all the input guys. DRAM, First off We primed it on the stand with a gauge attached. It showed 75 LBS. constant with a high torque drill. Don't know what else to expect Last night I drained the Rotella and this morning tried a 5w-30. As the motor warmed up the pressure fell to about 75 at idle and was around 85 at 3500-4000. It looked as if it would continue to fall as the motor got hotter. I had the temp up to 160. Of course that's not necessarily the oil temp but it seems to prove as the motor gets warmer the oil pressure is falling into place. The old oil pump stated at 65 regardless if it was hot or cold.
[Re: dc426]
#702605
05/20/10 11:44 AM
05/20/10 11:44 AM
Posts: 2,177 ill
dennismopar73
ill
oil filter 101 if you see 85 -100 psi at youre gauge that is about normal race car some motors are restricting the top end ,either in the block or heads?? so you could see increase of pressure that way youre gauge is usauly last in line to see pressure pump does accumulate most of the pressure rest is generated by mains cam bearings? as for filters they are restriction as well the race filter are far less restricted than that of normal cars reason not much filtration inside in other words it allows more oil to thru mmm after idle the filter doesnt filter much oil at all and at speed say above 1500 rpm very little oil actually goes thru that filter the filter cannot accept that flow so it bypasses it altogehter in passing a race filter filters out less particules than a reg filter does but will allow more oil thru it faster rate reg filter will filter more smaller particules thru it but allow less oil thru it does it matter ?? so long as you filter doesnt burst ?? not telling you to run cheap filter not telling you to run the best there is either with alcohol you have to be carefull as some dont like the water condensation
[Re: dennismopar73]
#702606
05/20/10 12:03 PM
05/20/10 12:03 PM
BobR
Left Coast
You may want to do a little research before calling someone else wrong. And if you used to "spec" diesel oil why don't know how to spell "diesel". Actually, Multi-weight oils (such as 10W-30) are a new invention made possible by adding polymers to oil
At cold temperatures, the polymers are coiled up and allow the oil to flow as their low numbers indicate. As the oil warms up, the polymers begin to unwind into long chains that prevent the oil from thinning as much as it normally would. The result is that at 100 degrees C, the oil has thinned only as much as the higher viscosity number indicates. Another way of looking at multi-vis oils is to think of a 20W-50 as a 20 weight oil that will not thin more than a 50 weight would when hot. Maybe we just aren't looking at this the same way but I absolutely know that in the instance of a 20W-50 oil the base stock IS 20W and the polymer additives give it 50W properties.
[Re: BobR]
#702607
05/20/10 12:24 PM
05/20/10 12:24 PM
Posts: 2,177 ill
dennismopar73
ill
ok we just had three valvoline reps in our store rep meeting some of what you say is almost correct but if say 20 is the starting oil in 20 w 50 no which is ashland oil, makers of several oil some independant oil they cannt say so the makers must be wrong then. heating of oil will make oil pressure seam to get lower here the result , everthing expandes as motor gets warm metal expandes you agree ?? so does rod main clearances cam etc so there is where most of that pressue goes away action reaction thing wounder how 0w 20 works mmm 0 wieght in my race car thatll work this is a good discussion i like it as for research me and my brother spect oil out so it does come from first hand knowlege as for spelling not in school and my typing skills not the best fat fingered and need new keyboard sorry for that i will stay after school and write it on the blackboard 100 x hahaha
[Re: MR_P_BODY]
#702608
05/20/10 12:29 PM
05/20/10 12:29 PM
for a HV pump on a smallblock with a std. spring (not hi pressure) and wider racing type bearing clearances, i normally see 65-70 lbs. while priming with a 1/2 HP 1/2" drill at 2400 rpm, which would be equivilent to 4800 rpm engine speed. as a rule the smaller 3/8 drills are 1/4-1/3 hp and are too weak to turn the pump at full rpm, so the pressure reading could vary quite a bit using one of those.
#702609
05/20/10 12:42 PM
05/20/10 12:42 PM
340B5
off the grid
Dis be whut de espurts say; Polymers expand and contract to both ends of the spec. Wt. @ 70* is somewhere in the middle. At least thats whut they teld me in automotive skool anyhoo.
[Re: dc426]
#702614
05/21/10 01:33 AM
05/21/10 01:33 AM
Chris'sBarracuda
Arizona
I would never pull an engine or the pan because my oil pressure was 5-10 pounds too high..
You can get real old really fast stressing about nothing..
Run it and have fun with it. Stop working on it..
Chris...
[Re: Sixpak]
#702615
05/21/10 10:31 AM
05/21/10 10:31 AM
Posts: 4,206 New York
polyspheric
New York
You may not see actual spark scatter, but it doesn't help.
pump does accumulate most of the pressure rest is generated by mains No true: the pump is only refreshing the leakage from the bearings. It provides only a very small proportion of the actual dynamic pressure, most of it is RPM × viscosity × journal OD.
Boffin Emeritus
[Re: polyspheric]
#702616
05/21/10 10:44 AM
05/21/10 10:44 AM
MR_P_BODY
IMHO, a small hole drilled through from the pump exterior to intersect the relief piston bore just ahead of the piston at full retraction will add to relief volume (and reduce overpressure), it just won't be recirculated. This is probably not true with all pumps, but my subject pump has a .420" relief piston (.138" area), but the relief port is only 11/32" diameter (.093" area), and only bypasses 67% of the possible volume. A single 7/32" hole to the exterior will only open when the piston is fully retracted and will not affect normal operation. This brings the total bypass dump area up to .130", almost the same area as the valve itself. No, I haven't tried it yet. Anyone see anything that's going to bite me?
To be honest I think that would work well... I dont foresee any issue because it would only open that port at or right near max open... which in case would help dump the aerated oil
Re: It's in, running and has too high oil pressure??? *DELETED*
[Re: MR_P_BODY]
#702617
05/21/10 11:24 AM
05/21/10 11:24 AM
polyspheric
New York
Post deleted by polyspheric
Boffin Emeritus
[Re: polyspheric]
#702618
05/21/10 11:29 AM
05/21/10 11:29 AM
MR_P_BODY
Thanks, I was afraid I was tripping over something obvious!
My subject pump has the piston just barely sealing the passage at rest, so enlarging the existing hole can only be done to the rear in any event. A diametric increase is not a good idea since it captures the piston from cocking upward under pressure. Some pistons may be possible to just reduce the length to allow it to reach full unmask position (or modify the retainer). Check the spring to make sure it doesn't bottom out 1st, etc.
I am assuming this pump you are working with is a in pan pump so you can dump the oil
[Re: dc426]
#702619
05/24/10 10:45 PM
05/24/10 10:45 PM
Posts: 1,466 malvern, ohio
3ddart
malvern, ohio
well, having posted here before, thought i'd update my progress, none!!! spent most of today switching out the sb oil pump i put in at the rebuild a month ago, it had over 100 lbs pressure and blew oil past the oilboss gasket onto the headers causing me to be black flagged. this happened above 4500 rpms. at idle it was 80 lbs and the 1 i replaced from last yr was 65lbs going down the track. 1 i put in today did exactly the same as the previous 1, reved it to about 4000 and saw smoke coming off the headers and sure enough it blew past the gasket again! now my ? is could i have done something on assembly to create this problem? pumps both came straight from melling (contingency reward) and block was cleaned with soap water and brake cleaner, honed by machine shop, and recleaned, crank was polished only and motor was reassembled. i have never had any problems like this before and thats why i'm reaching out to those of you in the know. always put some oil in the pump and assembled my motors before this and pressure was 50 to 60 at hot idle and 70 to 80 going down the track. i called melling about the 1st pump and they said they're not aware of any issues with these pumps. i called today but it was after hrs so i'll see what they say tomorrow. but in the meantime any suggestions on something i could have messed up on assembly? as always thanks in advance and thanks tom!! dave
[Re: 3ddart]
#702620
05/24/10 11:09 PM
05/24/10 11:09 PM
MR_P_BODY
I really dont think its you... sounds like they have a by-pass spring issue.... you put on 2 different pumps only to have the same issue... I would say that takes you out of the problem... you could cut the by-pass spring down some.... or take the spring out of your old pump(from the original pump that worked) clean it and install it in your new pump.... and make sure the little piston/cup moves freely
[Re: MR_P_BODY]
#702621
05/24/10 11:24 PM
05/24/10 11:24 PM
Posts: 1,880 USA
Ron Silva
USA
I think you said you changed the bearings? I think you literally have a good tight engine and you have to go to a standad volume Pump. You have too little flow required and the PP bypass cannot handle it. Basic physics. Most race engines in the past used big bearing clearances and big if not huge rod side clearances and needed the high volume PP. You probably have stacked all your clearances to the small side. I sure hope you did not do all that work and put another HV pump in there. Sorry if you did.
So your bearing clearances are nice and tight and possibly the Rod side clearances. Main Rod and rod side clearances affect oil pressure the most. Well rod side clearances could affect pressure if they were way too tight. Be sure and check them.
SRT DEMON ONE SEAT
[Re: MR_P_BODY]
#702623
05/25/10 09:02 AM
05/25/10 09:02 AM
Posts: 3,695 nc
emarine01
nc
We had the same problem with HV melling in our small block, we swaped springs from a old pump and have 64 psi just about all the time, when the oil gets real hot it falls to 45 @ idle and goes right back to 64 with any rpm increase, good luck , pullin the pan was a PITA but solved the problem
[Re: 3ddart]
#702625
05/25/10 10:29 PM
05/25/10 10:29 PM
Posts: 892 USA
krw71ragtop
USA
Look what 100 psi did to the filter on the left. I consider myself lucky I cought it. 416" sb
