91 Spirit...speedo and odometer not working...
#70180
06/08/08 10:49 PM
06/08/08 10:49 PM
Posts: 93 Anacortes, WA
russ71satellite
Anacortes, WA
Is the speed/distance sensor about the only likely cause of a speedo and odometer not working in a 91 Spirit? Thanks for the help..
71 Satellite Sebring, all stock 1989 Dodge Daytona, daily driver 2008 PT Cruiser
Re: 91 Spirit...speedo and odometer not working...
[Re: russ71satellite]
#70181
06/09/08 12:58 AM
06/09/08 12:58 AM
[Re: burdar]
#70184
06/09/08 04:48 PM
06/09/08 04:48 PM
Posts: 3,546 stratford,ontario,canada
JD340
I used to have a 91 Daytona and the speedo acted up. Sometimes it wouldn't work, sometimes it would. Sometimes while decellerating from 70mph the speedo would stick on 70 for a while before dropping to normal. I put a speed sensor in it and didn't have any more problems. Hope that helps!
Don't wanna hijack, but I was gonna post this question as well. 97 Neon, same symptoms as above,except for the sticking. Is it worth the time to remove the sensor and clean connections, or should I just replace it?
Nothing to see here. Carry on.
[Re: JD340]
#70185
06/09/08 04:51 PM
06/09/08 04:51 PM
Posts: 18,389 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
You should check for fault codes first. If there is one it could be a sensor. Also verify if the odometer does not work at the same time. If it does work and the mph needle does not the problem could be in the speedo head/cluster.
[Re: NITROUSN]
#70186
06/09/08 05:36 PM
06/09/08 05:36 PM
JD340
"You should check for fault codes first. If there is one it could be a sensor. Also verify if the odometer does not work at the same time. If it does work and the mph needle does not the problem could be in the speedo head/cluster." When the speedo quits, the odo and trip meter also quit. Have scanner, will check! Now, will scanner show a code if the speedo IS working at the time I plug in the scanner? Or only when the speedo is dead?
[Re: JD340]
#70187
06/09/08 06:00 PM
06/09/08 06:00 PM
NITROUSN
If the speedo does not work the computer should induce and store a code.
[Re: rrunner]
#70189
06/10/08 12:09 AM
06/10/08 12:09 AM
russ71satellite
Anacortes, WA
thanks for the info...yep, this car does not have a cable.
Could it also be a broken tooth on the gears in the speedo? I hope not...
[Re: NITROUSN]
#70191
06/10/08 12:37 PM
06/10/08 12:37 PM
JD340
Scanned it this morning. No codes. No speedo,odo, etc for most of the time I was running around this morning. Came back to life a couple miles from home. I'll order up the speed sensor. Hopefully it does the trick.
[Re: DaytonaTurbo]
#70193
06/10/08 01:07 PM
06/10/08 01:07 PM
Posts: 10,666 North Dakota
6PakBee
North Dakota
This is kinda 'backyard' but if you have cruise, set the cruise control. If the car goes out of cruise when the gauges die, it could be the speed sensor. If the car does not drop out of cruise, then it's probably the gauge cluster. As to the Neon cluster, Google something like 'Neon gauge problem'. This failure seems to be common.
[Re: DaytonaTurbo]
#70194
06/10/08 01:11 PM
06/10/08 01:11 PM
NITROUSN
If the speed sensor pops back to life at all, even for a second, it'll automatically clear the code in the computer. Mine was like that too, intermittantly dieing, changed speed sensor and all was good.
It will not automaticly clear the code. The code will stay for aprox 50 ignition cycles.
[Re: NITROUSN]
#70195
06/10/08 01:55 PM
06/10/08 01:55 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
Just a piece of info I run a trans shop and have had many chrylers come in with speedo problems speedo not working and they had not set one code at all put the scanner on and go to data and no reading from output sensor but no codes so just because there is not a code that doent mean the speed sensor isnt bad.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: NITROUSN]
#70196
06/10/08 03:47 PM
06/10/08 03:47 PM
DaytonaTurbo
Manitoba, Canada
Sure about that? Cause mine never set a code and I checked it a few times. But change the sensor and problem was gone forever...?
[Re: DaytonaTurbo]
#70197
06/10/08 04:05 PM
06/10/08 04:05 PM
NITROUSN
Yes. Once the code is set and the problem iscorrected or does not happen again you have to either reset with a scan tool or the older ones should clear in 50 ignition cycles.
Read your post. You said it automaticly clears itself.
[Re: 340Scamp]
#70199
06/10/08 07:48 PM
06/10/08 07:48 PM
dusturbd340W5
Kissimmee Fl.
like I said above I have had a number of them in the shop with bad speed sensor that never set a code
[Re: dusturbd340W5]
#70200
06/10/08 08:17 PM
06/10/08 08:17 PM
Posts: 6,016 Morningside
AdventurerSport
waaaay out there in left field
Morningside
My '91 Acclaim did that a few years ago...no speedo/odo, no code, but changed the sensor and been fine ever since...almost 80,000 miles ago...:)
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
[Re: AdventurerSport]
#70201
06/11/08 10:50 PM
06/11/08 10:50 PM
russ71satellite
Anacortes, WA
just checked for codes, and I'm getting a 38. this is a 3.0L. Does anyone know what this code is? Also, when I turn the key quickly to read the code, occasionally the speedo needle pegs, then goes back down. What does that mean?
#70202
06/12/08 10:21 PM
06/12/08 10:21 PM
russ71satellite
Anacortes, WA
bump...
speedo needle bounces and pegs while I turn key to read codes...any ideas what that means?
#70203
06/13/08 09:27 AM
06/13/08 09:27 AM
dusturbd340W5
Kissimmee Fl.
shop key shows 38 being lock up control problem
[Re: dusturbd340W5]
#70204
06/13/08 11:16 PM
06/13/08 11:16 PM
russ71satellite
Anacortes, WA
Replaced the speed sensor today, but no help...
[Re: burdar]
#70206
06/13/08 11:25 PM
06/13/08 11:25 PM
russ71satellite
Anacortes, WA
the gear looks good. It was of course attached to the old sensor, but I checked it and clipped it onto the new sensor.
#70207
06/16/08 09:54 AM
06/16/08 09:54 AM
JD340
Hey Russ, it's the Hijacker here. Messed around with my Neon the better part of Saturday. New speed sensor=NO change. Started tearing into gauge cluster. Poor connection between cluster and dash wiring. Gave terminals a little twist to improve connection. Result: still intermittent at best. Built up terminals with a little solder. Same result! Maybe there is a break in the wiring somewhere. I haven't found it yet! I feel your frustration with this. We probably put 10-15 miles on the car, on the hoist trying to find the "sweet" spot where the speedo would run consistently. If we ever trace it down, I'll give you a heads up.
