Who Sells Fan Clutch Studs (w/nuts and washers) #69675
06/08/08 08:14 AM
06/08/08 08:14 AM
Massachusetts
LYNCHROAD69.5 Offline OP
Massachusetts
These are the four studs (like manifold studs) that connect the fan blade to the clutch. Can't find these anywhere.
Re: Who Sells Fan Clutch Studs (w/nuts and washers) [Re: LYNCHROAD69.5] #69676
06/08/08 09:59 AM
06/08/08 09:59 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Gibson/Badalson sells them and I am sure that some of the others like Bill Alphin and the like sell them.
FWIW, you can also go to Home Depot and get a set of four studs that are threaded on both ends(5/16). They usually come NF on one end and NC on the other. They will work, you just have to cut a few threads off(too long). Dress the cut end on a grinder and put a dab of grey paint on the exposed cut end and they will look like the real Mc Coy.
Mike
Re: Who Sells Fan Clutch Studs (w/nuts and washers) [Re: HPMike] #69677
06/08/08 05:48 PM
06/08/08 05:48 PM
Massachusetts
Massachusetts
mike, thanks for the lead.
