Re: Shimming Rockers [Re: ahy] #695747
05/24/10 03:50 AM
05/24/10 03:50 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
get shims from Hughes , Mancini , etc..
you want .015 to .030 clearance. Keep in mind some of the hold downs can be moved a little to change clearance.
Re: Shimming Rockers [Re: 493_DART] #695748
05/24/10 07:31 AM
05/24/10 07:31 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
If the question i sdo any come without shims, the answer is some come with springs but shims are the correct way to center the rocker. The better sets of rockers still use shims. It's part of the engine building process on a performance engine.
I'll also ad to JohnRRs answer on shimming the rocker shafts to correct the geometry that the valve job is the only thing on a saddle type shaft rocker that affects geometry. Well, sometimes different rocker ratios and manufacturers might a little too, but it's basically the valve job.
