need a pic of a 1964 belevedere 318 engine #69547
06/07/08 10:44 PM
06/07/08 10:44 PM
mt.ephraim , new jersey
jsmopar1072 Offline OP
i know its red but i need to see what was painted and what wasnt thanks,please post a pic for me thank you, jeff
WINNING IS ALL LUCK,ASK ANY LOSER! OBJECTS IN MIRROR APPEAR TO BE LOSING! JEFF'S BUDGET DODGE GARAGE!!!!
Re: need a pic of a 1964 belevedere 318 engine [Re: jsmopar1072] #69548
06/08/08 12:53 AM
06/08/08 12:53 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
OK, here's mine. Hose between intake & water pump was painted as it was on LA motors. Fuel pump appeared to have paint on it, as did distributor hold-down & a little overspray on distributor. It all looked pretty original when I got the car, only 1 coat of paint on the valve covers as far as I could see.
Sharp eyes will notice a few firewall plugs and 2 screws in the firewall to the left of the MC, all of which were mods for an aftermarket A/C unit that I yanked. Plug wires should be black, distributor caps were black IIRC.
My PS pump is natural (bare metal), may or may not be original, but appears so, brackets semi-gloss black. Balancer red, pulleys semi-gloss black as far as I could tell. Throttle bracket was engine color, as on later models. There was some red paint still visible on the exhaust manifolds. Throttle return spring burgundy.
Re: need a pic of a 1964 belevedere 318 engine [Re: jsmopar1072] #69549
06/08/08 02:06 PM
06/08/08 02:06 PM
Kansas
64Belvedere Offline
super street
64Belvedere  Offline
super street
Kansas
Here's mine. Ignore the rust and chipped paint on the engine compartment.... I've taken some liberties with the engine, but tried to keep an OEM "look" and repainted everything the same color as it was originally.
[image][/image]
