Will '71 B-body Exhaust fit a 69 B-body? #694841
05/11/10 12:41 PM
05/11/10 12:41 PM
Wisconsin
wkroncke17 Offline OP
Wisconsin
I found a 2-1/2" full dual exhaust from HP manifolds back that was on a '71 Roadrunner for cheap.
Will it fit on a '69 Coronet? (or can it be modified easily enough to fit?)
Thanks!!
Re: Will '71 B-body Exhaust fit a 69 B-body? [Re: wkroncke17] #694842
05/11/10 01:50 PM
05/11/10 01:50 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I can't say with the factory stuff, but I had a 72 Satellite/RR with a 440 that had the headers and full exhaust off of a 69 Road Runner installed on it. It seemed to clear everything okay.
The entire drive train and exhaust was swapped into the car.
One thing though, the 71 R/S exhaust flange will be clocked (indexed/ timed/ twisted) different than a 69. That's the difference between a R/S 71 and 69 exhaust manifold (besides the obvious part number difference).
You'd have to use a R/S 69 exhaust manifold without having the exhaust pipe flange reworked/turned.
Re: Will '71 B-body Exhaust fit a 69 B-body? [Re: wkroncke17] #694843
05/11/10 05:32 PM
05/11/10 05:32 PM
indiana
generallee6901 Offline
indiana
Tail pipes are a different length.I took the tail pipes off of a 68 charger and put them on a 71 roadrunner and had to cut a bunch off.Do not remember how much.Will have to add on to them.
Re: Will '71 B-body Exhaust fit a 69 B-body? [Re: generallee6901] #694844
05/11/10 07:38 PM
05/11/10 07:38 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The mounting flanges may not be oriented in the same way between the 2 cars; IIRC, '68 & '69 have the flange bolt locations in the same place but '70-up is different, and I don't know if it changed again in '71 and/or later. Not a big deal, though.
