Parking on hill w/manual trans, which gear is best? #68726
06/06/08 05:05 PM
06/06/08 05:05 PM
Oklahoma
Mopar72Man Offline OP
Oklahoma
When parking on a hill which gear would be best to leave the trans in, 1st or 4th? I say 4th, friend says 1st...for some reason in my head im thinking 4th will be harder to turn the engine over...but its been a looooong week!
72 Challenger - will be sublime, little 340 904, 8 3/4" - Under Construction
Re: Parking on hill w/manual trans, which gear is best? [Re: Mopar72Man] #68727
06/06/08 05:08 PM
06/06/08 05:08 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
1st or reverse depending on the hill, AND the parking brake.
Re: Parking on hill w/manual trans, which gear is best? [Re: Aero426] #68728
06/06/08 05:12 PM
06/06/08 05:12 PM
Oklahoma
Oklahoma
Still not quite what im lookin for, but WHY 1st and not 4th?
Re: Parking on hill w/manual trans, which gear is best? [Re: Aero426] #68729
06/06/08 05:14 PM
06/06/08 05:14 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
1st or reverse, which ever one is numerically higher. Say first gear is 4:1, so one turn of the driveshaft is 4 turns of the engine. In fourth gear of say .75:1, 1 turn of the driveshaft is only .75 turns of the engine. Now which is easier, turning the engine 4 times or .75 times.
Re: Parking on hill w/manual trans, which gear is best? [Re: bordin34] #68730
06/06/08 05:20 PM
06/06/08 05:20 PM
Oklahoma
Oklahoma
last time i checked though, say you were push starting the engine..using the starter. You'd sure move a lot better/easier in first than you would 4th. What about an overdrive application? even 'easier' to turn the engine? 1st being a big gear turning a little gear would be easier to turn thanks to the torque of that setup. Say a 5th gear where a little gear would have to turn a larger gear, it'd take more to actually do that..just how it is in my head
Re: Parking on hill w/manual trans, which gear is best? [Re: Mopar72Man] #68731
06/06/08 07:04 PM
06/06/08 07:04 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Think it has something to do with torque multiplication. assuming a 3 to 1 1st gear and a 1 to 1 first gear with the engine driving the input shaft the rear sees a 3 to 1 torque multiplication but with the rear wheels driving the input shaft it there would be a 1/3 torque multiplication divide by 3) When in 4th gear (1:1) and the input shaft has the same torque (i.e. more likely to turn the engine over). When driving, downshifting offers braking.
I think
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Parking on hill w/manual trans, which gear is best? [Re: Mopar72Man] #68732
06/06/08 07:41 PM
06/06/08 07:41 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
or easier to slip the clutch. My old man would never leave the '53 or '57 Plymouths in gear when parked; said if someone bumped you, could chip a gear. Of course not too many steep hills in Fresno, and old MOPARS had a POWERFUL parking brake on the driveshaft.
Re: Parking on hill w/manual trans, which gear is best? [Re: DZJim] #68733
06/06/08 07:44 PM
06/06/08 07:44 PM
Kirkland, Washington
Pacnorthcuda Offline
This is actually a great question. I think there is more to it than the gear ratio--like the point at which the clutch will just slip and NOT require the engine to turn. I always put my car in SECOND gear, but I will admit I never really thought real hard about it.
Re: Parking on hill w/manual trans, which gear is best? [Re: Mopar72Man] #68734
06/06/08 08:14 PM
06/06/08 08:14 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Use 1st or reverse if parking on a hill.Think about push starting a car with manual trans,you use 3rd or 4th because it's easier to turn the motor,if you use 1st the motor will stop the car or be extremely hard to push.Thats what you want when parked on a hill,extremely hard to push and yes its due to the gear ratio.
Re: Parking on hill w/manual trans, which gear is best? [Re: Ply72rr] #68735
06/06/08 08:32 PM
06/06/08 08:32 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I use first or reverse in my car with the parking brake. When I am done with the car totally as stock, my key only comes out when it is in reverse from the factory
Re: Parking on hill w/manual trans, which gear is best? [Re: Mopar-Al] #68736
06/06/08 09:23 PM
06/06/08 09:23 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I don't think it matters which gear because there should be two preceding factors which should keep your car from even moving when parked on a hill:
1) Turning you front tire at an angle so it's touching the curb
2) Setting the parking brake
