Oil Leak....arggg #68715
06/06/08 04:43 PM
06/06/08 04:43 PM
Nanuet, NY
3
383BeepBeep Offline OP
Nanuet, NY
I am having no luck with this one leak from the oil pan. I have successfully created an even bigger leak(I have no luck with large cork gaskets). The oil pan has been checked for straightness as has the block. I am using a windage tray. Can I get a way with Black RTV? Any suggestions. I am glad it isn't a customers car.
1969 Plymouth Roadrunner - 383- 4 Speed - Dana 60 4:10
Re: Oil Leak....arggg [Re: 383BeepBeep] #68716
06/06/08 04:46 PM
06/06/08 04:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
it's the gasket , i HATE those cork gaskets .
along with the flange being straight it has to be FLAT and cork gaskets are the biggest player in ruining the flatness of that oil pan flange if you over tighten the bolts , which is easy top do with that gasket
Re: Oil Leak....arggg [Re: 383BeepBeep] #68717
06/06/08 05:26 PM
06/06/08 05:26 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Are you absolutley SURE the leak couldn't be comming from the front cover crank seal? I ask because I struggled with that years ago--I was SURE it was the pan. The front crank can leak and the windage of the fan spray it back and down (of course) and all you see is it collecting on the pan flange looking to all the world like a pan leak......
Re: Oil Leak....arggg [Re: 383BeepBeep] #68718
06/06/08 09:48 PM
06/06/08 09:48 PM
Nanuet, NY
3
Nanuet, NY
Just got back from the shop....front cover is fine. I just RTVed the snot out it(on advice from a F.A.S.T class friend). Hope it works. Thanks guys
