rear main seal retainer fix #68643
06/06/08 02:42 PM
06/06/08 02:42 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang.....
I'm trying to fix the situation where the dang seals stretched and ripped while I was installing the retainer because of the tight tolerances and the thickness of the seals down the side.... Sooooo, the retainer is perfectly fine.. Can I use RTV in the seal channels inlew of the rubber seals that have torn? I've gotten some responses to my post looking for a retainer and I thank all those individual... If I can fix it with this, then I'll buy one of the OEM units and just use that... Here's what I'm working with on my Hemi....
Cheers,
Troy
Houston Mopar Connection Club
Re: rear main seal retainer fix [Re: hemi68charger] #68644
06/06/08 02:43 PM
06/06/08 02:43 PM
Houston, Tx
Houston, Tx
In the cavity...
Troy
Re: rear main seal retainer fix [Re: hemi68charger] #68645
06/06/08 03:05 PM
06/06/08 03:05 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I wouldnt use silicone in the sides. There isn't a way to know its covered properly from the sliding motion.
I just cut regular 1/8 orings open for the side seals and put a few dabs of crazy glue to hold oring in the retainer as it slides in.
Re: rear main seal retainer fix [Re: hemi68charger] #68646
06/06/08 03:17 PM
06/06/08 03:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
troy i have that same retainer and ran into the same thing , i was going to try the RTV trick on it, but i just dug out an old retainer and used it
Re: rear main seal retainer fix [Re: hemi68charger] #68647
06/06/08 03:41 PM
06/06/08 03:41 PM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
You might want to offset the seal and put a dab of black rtv on the ends.
For the side seals I have used black rtv and the wicks working good.
