Valve springs and seals #68632
06/06/08 12:12 PM
06/06/08 12:12 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
I have these springs,
http://store.summitracing.com/partdetail...mp;autoview=sku
Took my valve covers off and some of the seals are torn up and laying next to the springs?
I used the stock seals, should I have used a different type?
I replaced them last year. 452 heads.
These are the seals,
Re: Valve springs and seals [Re: DAMOPARS] #68633
06/06/08 12:37 PM
06/06/08 12:37 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Stock type seals should be no problem with a single spring with a damper. Where they run into problems is with a true multiple spring which a spring with a damper is not.
Re: Valve springs and seals [Re: MoparforLife] #68634
06/06/08 12:46 PM
06/06/08 12:46 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
Looks like it was the flater larger seals are the ones that were torn up. I can't remember which ones these were intake or exhaust.
Why did they wear out so soon?
Is there a better seal?
Re: Valve springs and seals [Re: DAMOPARS] #68635
06/06/08 08:28 PM
06/06/08 08:28 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My machinist uses teflon seals.The old heads were on for 7 years with comp springs that were duals.He installed the same seals with the new aluminum heads and the same Comp springs as I had on the old heads.Rocky
Chrysler Firepower
