Page 1 of 7 1 2 3 4 5 6 7
Running hot with 440 source housing and pump #685443
05/01/10 02:36 PM
05/01/10 02:36 PM
dark side of the moon
Dougsmopars Offline OP
My 440 ran 190 on hottest days. Installed new cam and went to 440 source water pump housing and pump. Car runs hot now and summer hasn't started. Will adding electric fan help or do i have to dump the 440 source parts?
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685444
05/01/10 02:40 PM
05/01/10 02:40 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you might want to check a few things. 1st check your timing, 2nd make sure your fan is close enough to the radiator. Some pumps have shorter snouts, 3rd check you air/fule mixture. If you add a cam and didn't make adjustments to your carb you could be lean.
Coming soon!!!!
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685445
05/01/10 02:40 PM
05/01/10 02:40 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
I have the same combo and its been great. Whats your t-stat?
Re: Running hot with 440 source housing and pump [Re: Viol8r] #685446
05/01/10 03:11 PM
05/01/10 03:11 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I had the same problem so I fitted a stock pump to the 440 Source housing and it runs cool again.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685447
05/01/10 03:13 PM
05/01/10 03:13 PM
beedees Offline
beedees  Offline
I remember reading here (or somewhere) that the passages on the w.p. housing were not the right size.
Re: Running hot with 440 source housing and pump [Re: beedees] #685448
05/01/10 03:17 PM
05/01/10 03:17 PM
NH
Fastback67 Offline
Fastback67  Offline
NH
Yes, the problem was the 440 Source Pump itself, and not the housing. The Pump doesn't move a lot of water, especially at low RPM's where it's needed the most.
Re: Running hot with 440 source housing and pump [Re: beedees] #685449
05/01/10 03:17 PM
05/01/10 03:17 PM
Yes it was on here & one side of the 440source housing was restricted. I'd pull the housing and iirc it's easy to spot. You made no other changes other than pump/housing? did you change the stat at the same time?
Re: Running hot with 440 source housing and pump [Re: RapidRobert] #685450
05/01/10 03:21 PM
05/01/10 03:21 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
The passages on the 440 Source housing are smaller than a stock housing but they are big enough. The problem is the pump, it flows well at high rpm but not enough at low rpm.
Re: Running hot with 440 source housing and pump [Re: RapidRobert] #685451
05/01/10 03:24 PM
05/01/10 03:24 PM
New 160 stat. Brand new 3 row rad. 18 inch clutch fan with shroud. Fan properly spaced. Carb adjusted a tad rich. timing set. Car isn't puking anti freeze but gauge is reading higher then it did. The 440 sorce houseing has the temp sensor on drivers side near head. My stock houseing had the temp sensor behind the nipple on passenger side. Am i getting a higher reading from that spot?
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685452
05/01/10 03:56 PM
05/01/10 03:56 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Re: Running hot with 440 source housing and pump [Re: NachoRT74] #685453
05/01/10 04:08 PM
05/01/10 04:08 PM
I guess i'll try swapping the pump and hope that cures it. Hate to have to pull the houseing now. Guess the 440 source parts are junk.
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685454
05/01/10 04:19 PM
05/01/10 04:19 PM
Just ordered the Milodon pump and high flow stat.
Re: Running hot with 440 source housing and pump [Re: Mick70RR] #685455
05/01/10 04:37 PM
05/01/10 04:37 PM
Kirkland, Washington
Pacnorthcuda Offline
I am wondering if this is the case. The 440Source pump impeller is radically different from stock, the Milodon, and the Edelbrocks. I have the 440source housing with the Edelbrock pump and it works OK, maybe not as well as it might with the stock housing but its not too bad.... (???)
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685456
05/01/10 04:47 PM
05/01/10 04:47 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Running hot with 440 source housing and pump [Re: Pacnorthcuda] #685457
05/01/10 05:21 PM
05/01/10 05:21 PM
I'm going to try the Milodon pump and see if that takes care of it. It's only 75 degree's out today and car is running hot. Definitly gonna over heat when it's 90 out.
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685458
05/01/10 06:39 PM
05/01/10 06:39 PM
New 160 stat. The 440 sorce houseing has the temp sensor on drivers side near head. My stock houseing had the temp sensor behind the nipple on passenger side. Am i getting a higher reading from that spot?
no, not a problem. I would suggest a 180 stat
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685459
05/01/10 06:46 PM
05/01/10 06:46 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'm betting it's your fan clutch, try another one.
180 stat would be best.
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685460
05/01/10 07:15 PM
05/01/10 07:15 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
The housing passage is the same size as the hole in the block that it feeds, so it is not a problem.
The pump is made by Cat and is sold by many different people.
This is the first that I heard it has an idle flow problem, but might be
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685461
05/01/10 07:38 PM
05/01/10 07:38 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Doug when you say it runs "hot" how hot is hot? Over 200 degrees I use the same housing that is sold by Mancini with a CV electric pump,16" puller fan,and aluminum 2 row radiator from Mancini and my 11-1 comp.street/strip engine runs 180 down the highway and 190-200 stop and go traffic. There are so many guys afraid of 200 degrees and that is NOT overheating
Gus
64 Plymouth Savoy
Dana 60
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685462
05/01/10 08:36 PM
05/01/10 08:36 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Many years ago I installed a new(rebuilt) waterpump from a reputable local parts place on my 440.
The car ran way hottter than before.
Changed thermostat with no improvment.
Old time mechanic told me to check the impeller on the NEW waterpump.
Sure enough the impeller was poorly pressed on and was loose and spinning on the shaft.
You might want to check how tight the impeller is.
