Re: Running hot with 440 source housing and pump
[Re: RapidRobert]
#685485
05/05/10 12:59 AM
05/05/10 12:59 AM
Posts: 4,230 State of retirement
52savoy
State of retirement
The pump is made by Cat and is sold by many different people.
I have a NIB cat pump going onto a mild 451
I have a CAT housing and pump with a 160 t-stat and I can't even get it past 160 degrees with a stock 22" radiator w/clutch fan. My 440 has 12-1 compression and a .600 lift cam. I did drill out the head gasket's water holes that were slotted.. Not sure how much diff that made.
[Re: 52savoy]
#685486
05/05/10 01:13 AM
05/05/10 01:13 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Most of my overheating problems went away as soon as I got rid of the underdrive crank pulley.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: GTXKen]
#685494
05/05/10 03:26 PM
05/05/10 03:26 PM
Posts: 130 Marcell, MN
68 Roadrunner
Marcell, MN
I'm curious to see what you guys find out. I just put on a 440 Source pump and housing on my new motor. I'm not quite done installing it. Hopefully I don't have this overheating problem!
1968 Roadrunner 383 auto
.060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
[Re: Challenger 1]
#685495
05/05/10 05:13 PM
05/05/10 05:13 PM
Posts: 936 own private Idaho
ngpSatellite
own private Idaho
something interesting to read about
Read the thread...that link was already posted in this thread. Just because someone post it, doesn't make it fact.
.... take it easy man... ........I have a 440 source housing and top end heat issues.... it will cost about 30 bucks to get a stock housing and swap it out... relax... you act like you work for 440 source
[Re: Challenger 1]
#685499
05/05/10 10:11 PM
05/05/10 10:11 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Well the one fact that is indisputable is that MY engine ran cooler with the stock housing and Milodon pump. There was also much better circulation across the top of the rad with this setup vs the 440 source housing & pump. That's a FACT !
INMO, the housing is a problem, anything that restricts waterflow in & out can't be good for cooling. Coolant that languishes inside the block & heads too long is going to boil.
Ron
[Re: firefighter3931]
#685500
05/05/10 10:45 PM
05/05/10 10:45 PM
Challenger 1
Cincinnati, Ohio
Ron
I hear you, and agree. Bummer 440challenger, can you or will you change out your Source housing to see if it cures your problem?
Isn't there guys here running the Source housing without overheating issues?
[Re: Challenger 1]
#685501
05/06/10 12:56 AM
05/06/10 12:56 AM
Posts: 10,198 Someplace you aren't
SomeCarGuy
What kind of stat are you running?
Some have the big slots, others have the more common small passage.
I want my fair share
