A body brake line "tee" fitting #68515
06/06/08 08:01 AM
06/06/08 08:01 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Any one know of a source or suitable substitute for the part labled "tee" in the service manual?
It is at the end of the main brake line coming from the front of the car and splits the line to each rear brake. It is mounted on top of the axle housing (on my car anyway)
This part is labled "5-58-1" on the diagram and is called out as part # 1118161 in the parts listing.
Darius
Driving modern convenience in classic beauty
Re: A body brake line "tee" fitting [Re: Darius] #68516
06/06/08 08:24 AM
06/06/08 08:24 AM
fort worth,tx
txterry2 Offline
super gas
txterry2  Offline
super gas
fort worth,tx
I think this is what you need.It is called a rear brake hose.You can get at auto parts store.
Re: A body brake line "tee" fitting [Re: txterry2] #68517
06/06/08 08:47 AM
06/06/08 08:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
no the tee is seperate on an a body
Re: A body brake line "tee" fitting [Re: JohnRR] #68518
06/06/08 12:02 PM
06/06/08 12:02 PM
fort worth,tx
txterry2 Offline
super gas
txterry2  Offline
super gas
fort worth,tx
That does fit post 73 cars.He was not specific on what he has.
Re: A body brake line "tee" fitting [Re: txterry2] #68519
06/06/08 12:30 PM
06/06/08 12:30 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Sorry guys,
I am looking to replace this in my 69 Dart GTS
Power front factory dics and drum rears.
Re: A body brake line "tee" fitting [Re: Darius] #68520
06/06/08 12:50 PM
06/06/08 12:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sorry guys,
do you not have one ?
its the same part disc or drum
Re: A body brake line "tee" fitting [Re: Darius] #68521
06/06/08 12:55 PM
06/06/08 12:55 PM
fort worth,tx
txterry2 Offline
super gas
txterry2  Offline
super gas
fort worth,tx
If your brake lines have a male fitting.You should be able to get a "T" with female fittings at a hardware store.
Re: A body brake line "tee" fitting [Re: JohnRR] #68522
06/06/08 01:28 PM
06/06/08 01:28 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
I have one but it needs to be replaced I think. it is leaking. I actually thought my rear end was leaking and I checked the fluid in there, it was fine and for some reason never thought about something else that could be leaking in that area. I was not able at that time to get into a position to see on top of the axle.
My brake pedal went mush on me so I started looking at the wheel areas to see if there was leakage and I got into a position where I noticed the fitting on top of the axle and realized it was brake fluid dripping off the pumpkin. I figured I would probably need a new fitting and could not find one at any of the usual parts places, hence the post.
Thanks for y'alls input.
Re: A body brake line "tee" fitting [Re: Darius] #68523
06/06/08 01:41 PM
06/06/08 01:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried tightening the lines yet. Normally the T doesn't need replacement. It's just a solid threaded block.
Re: A body brake line "tee" fitting [Re: stumpy] #68524
06/06/08 02:06 PM
06/06/08 02:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: A body brake line "tee" fitting [Re: JohnRR] #68525
06/06/08 02:46 PM
06/06/08 02:46 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Workin on that today, hopefully that is all it needs.
i just thought I would fish for sources in case it was bad enough to need a new one.
Thanks John
Re: A body brake line "tee" fitting [Re: Darius] #68526
06/06/08 03:30 PM
06/06/08 03:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
your sources are USED .... that i have ever seen
Re: A body brake line "tee" fitting [Re: JohnRR] #68527
06/06/08 03:47 PM
06/06/08 03:47 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
unless you buy the one pictured above. Theyre all pretty much the same for the same rear housing. I put a late B one-piece unit on my 65, no issues. In my book its one less place to have a leak
Re: A body brake line "tee" fitting [Re: JohnRR] #68528
06/06/08 03:49 PM
06/06/08 03:49 PM
ONE OF THESE
Re: A body brake line "tee" fitting #68529
06/06/08 04:43 PM
06/06/08 04:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
ONE OF THESE
Re: A body brake line "tee" fitting [Re: JohnRR] #68530
06/06/08 06:14 PM
06/06/08 06:14 PM
JOHN
your to funny
see ya at carlisle this year ?
