A body brake line "tee" fitting
#68515
06/06/08 08:01 AM
06/06/08 08:01 AM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
Any one know of a source or suitable substitute for the part labled "tee" in the service manual? It is at the end of the main brake line coming from the front of the car and splits the line to each rear brake. It is mounted on top of the axle housing (on my car anyway) This part is labled "5-58-1" on the diagram and is called out as part # 1118161 in the parts listing. Thanks Darius
Driving modern convenience in classic beauty
Re: A body brake line "tee" fitting
[Re: txterry2]
#68517
06/06/08 08:47 AM
06/06/08 08:47 AM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
I think this is what you need.It is called a rear brake hose.You can get at auto parts store.
no the tee is seperate on an a body
[Re: txterry2]
#68519
06/06/08 12:30 PM
06/06/08 12:30 PM
Darius
Sacramento, Ca
Sorry guys, I am looking to replace this in my 69 Dart GTS Power front factory dics and drum rears.
[Re: Darius]
#68520
06/06/08 12:50 PM
06/06/08 12:50 PM
JohnRR
U.S.S.A.
do you not have one ?
its the same part disc or drum
[Re: JohnRR]
#68522
06/06/08 01:28 PM
06/06/08 01:28 PM
Darius
Sacramento, Ca
I have one but it needs to be replaced I think. it is leaking. I actually thought my rear end was leaking and I checked the fluid in there, it was fine and for some reason never thought about something else that could be leaking in that area. I was not able at that time to get into a position to see on top of the axle. My brake pedal went mush on me so I started looking at the wheel areas to see if there was leakage and I got into a position where I noticed the fitting on top of the axle and realized it was brake fluid dripping off the pumpkin. I figured I would probably need a new fitting and could not find one at any of the usual parts places, hence the post. Thanks for y'alls input.
[Re: stumpy]
#68524
06/06/08 02:06 PM
06/06/08 02:06 PM
JohnRR
U.S.S.A.
Have you tried tightening the lines yet. Normally the T doesn't need replacement. It's just a solid threaded block.
[Re: JohnRR]
#68525
06/06/08 02:46 PM
06/06/08 02:46 PM
Darius
Sacramento, Ca
Workin on that today, hopefully that is all it needs. i just thought I would fish for sources in case it was bad enough to need a new one. Thanks John
[Re: JohnRR]
#68527
06/06/08 03:47 PM
06/06/08 03:47 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
your sources are USED .... that i have ever seen
unless you buy the one pictured above. Theyre all pretty much the same for the same rear housing. I put a late B one-piece unit on my 65, no issues. In my book its one less place to have a leak
[Re: JohnRR]
#68528
06/06/08 03:49 PM
06/06/08 03:49 PM
#68529
06/06/08 04:43 PM
06/06/08 04:43 PM
JohnRR
U.S.S.A.
ONE OF THESE
[Re: JohnRR]
#68530
06/06/08 06:14 PM
06/06/08 06:14 PM
JOHN your to funny see ya at carlisle this year ?
