manual steering box master spline #68311
06/05/08 11:35 PM
06/05/08 11:35 PM
Nashport, OH
chargers777 Offline OP
Nashport, OH
My manual box does not have a master spline.I thought all steering boxes did.Car is a 73 duster but I am not sure what a body the box came out of.How do I lineup the steering coupler to the box so that my steering wheel is straight.
Re: manual steering box master spline [Re: chargers777] #68312
06/06/08 05:57 PM
06/06/08 05:57 PM
Nashport, OH
Nashport, OH
Anyone?
Re: manual steering box master spline [Re: chargers777] #68313
06/06/08 06:25 PM
06/06/08 06:25 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
See how many turns it is lock to lock. The put the pitman arm on in the middle, have your wheels straight, put your idler arm on straight like the pitman arm, install inner n outer tie rods with the sleeves, have your steering wheel centered where you want it and make a way to hold it there beit tied down, a book wedge under it and the seat, snug up the castle nuts to everything and then set the toe with a tape measurer. Seems it should have a spline missing on the box shaft though. Still doesnt sound hard to do. You can get it very close and drive or trailer it to an alignment shop. Did you do the whole front end? If so, you need to get the caster and camber close and snuged down before you do what I have just typed.
Re: manual steering box master spline [Re: chargers777] #68314
06/06/08 06:58 PM
06/06/08 06:58 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
You will more than likely have to remove a spline for the coupler to fit.
I used an angle grinder and a steady hand to do mine.
The 20:1 mopar kit I used did not have a master spline.
Try to center everything then choose the closest spline to remove.
