seatbelt cleaning boiling water and what cleaner #68144
06/05/08 05:37 PM
06/05/08 05:37 PM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
what do you put in the water when cleaning the seatbelts in boiling water? do you just put the entire seatbelt in the boiling water
Re: seatbelt cleaning boiling water and what cleaner [Re: satgtx] #68145
06/05/08 05:48 PM
06/05/08 05:48 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Um I don't know about the boiling water, but nylon melts it. I used a pressure washer on mine and they
look like brand new with only water.
Re: seatbelt cleaning boiling water and what cleaner [Re: Dart 340] #68146
06/05/08 06:21 PM
06/05/08 06:21 PM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
ok i will try that.
thanks
Re: seatbelt cleaning boiling water and what cleaner [Re: satgtx] #68147
06/05/08 07:06 PM
06/05/08 07:06 PM
florida
74fldart Offline
74fldart  Offline
florida
ive had good luck with purple power degreaser on them
Re: seatbelt cleaning boiling water and what cleaner [Re: satgtx] #68148
06/05/08 07:27 PM
06/05/08 07:27 PM
USA
stan1970 Offline
stan1970  Offline
USA
How bad did the belts look before? Was there a lot of crud on them - and that is what the washing will fix?
Mine are old and very faded ... I'd love to freshen up the look, but I'm afraid that washing them will make them worse...
If it works for you, I'll give it a try too!
Re: seatbelt cleaning boiling water and what cleaner [Re: stan1970] #68149
06/05/08 08:30 PM
06/05/08 08:30 PM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
i read in mcg magazine a few years back that you could boil them with some cleaner. I did it and just put some degreaser in it and they are a lot better. The material is great but the metal needs to be cleaned more. i got the belts from Tony D. and they are in great shape.
they did not discolor at all.
Re: seatbelt cleaning boiling water and what cleaner [Re: satgtx] #68150
06/05/08 08:45 PM
06/05/08 08:45 PM
Kirkland, Washington
Pacnorthcuda Offline
I don't think I used a cleaner when I did mine but I did use rit dye and salt when boiling/dying them--worked GREAT. I was paranoid the black would bleed on the wifes clothes some day when we were crusing (she would kill) but it doesnt. Whut them fabrik peeple kall kolorfast!!!!
Re: seatbelt cleaning boiling water and what cleaner [Re: Pacnorthcuda] #68151
06/05/08 09:22 PM
06/05/08 09:22 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
simple green ?
soylent green ?
Re: seatbelt cleaning boiling water and what cleaner [Re: mark7171] #68152
06/05/08 09:49 PM
06/05/08 09:49 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
did mine in simple green/water mix soaking in a bucket and scrub them with a brush...sun dry...
Re: seatbelt cleaning boiling water and what cleaner [Re: AARCONV] #68153
06/06/08 12:09 AM
06/06/08 12:09 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
anyone try having them dry cleaned? seems like the simplest solution
