Who's running a Mancini HV water pump? #68124
06/05/08 05:13 PM
06/05/08 05:13 PM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
I put a Mancini HV water pump on my new stroker. With everything bolted up (I'm 99.9% certain that my fan bolts are tight) and the belt on there seems to be a little play in the shaft. I'm not particularly comfortable with this.
Anybody else got/had the same problem?
Re: Who's running a Mancini HV water pump? [Re: Damned67] #68125
06/06/08 05:31 PM
06/06/08 05:31 PM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
Anyone?
I'm sure I'm not the only one running a Mancini pump?
Re: Who's running a Mancini HV water pump? [Re: Damned67] #68126
06/06/08 08:39 PM
06/06/08 08:39 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
There should be no play in the shaft.
Re: Who's running a Mancini HV water pump? [Re: earlybee] #68127
06/06/08 09:28 PM
06/06/08 09:28 PM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
That's pretty much what I thought.
Yippee! Another junk product that I've wasted my money on.
So, anybody else experienced this with the same pump, or is this a one off failure?
Re: Who's running a Mancini HV water pump? [Re: Damned67] #68128
06/07/08 02:47 AM
06/07/08 02:47 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Mancini will help if you contact them.
