Young gun needing last generation advice
#681194
04/26/10 08:41 PM
04/26/10 08:41 PM
Posts: 583 San Antonio, TX
CurYellowBird
San Antonio, TX
Ok this is the issue I'm having. After speaking with a friend of my father who has his own 71' Roadrunner (and an original 440+6 superbird)he has helped shed new light for me.
I'm not sure if he kept his original 383 or not, but he now has a 440+6 in his roadrunner as well. As we went through what all I wanted to do with my 71' Roadrunner and what I had for parts to make a 550hp/550lb 440 for the roadrunner. This is what I have to work with:
-440 virgin RV block (30k miles) -XE285HL comp cams cam (.545/.545 lift) -750 Barry Grant carb -Large dual plane intake -mini starter
This is just what I have so far as performance parts. I know how this cam behaves as my father runs it in his 440 67' Dart GTS. It runs like a raped ape!
But I think the one thing that kinda made me feel out of place was his comment "Those days are over. No one races on the street anymore cause you will go to jail and these cars have become too valuable." His big point was keeping the car original as it will be more fun than going all out like I was planning. His biggest suggestion was going with a .474/.474 camshaft and leaving it at that and maybe a good set of heads.
So what do you guys think of all this? I've always felt like I was born in the wrong era or generation as I listen to all music from the 60's and 70's, love the cars, loved the thoughts of people in those days, and how they were somewhat simpler than what they are today. I don't know of too many kids who are 19 that share the same passion (at least not around me) that don't drive rice burners and have no moral values.
Project War Bird:
1971 Plymouth Roadrunner
383 4 speed with air conditioning
GY3 Curious yellow
All original
Re: I need a wake up call lol
[Re: CurYellowBird]
#681195
04/26/10 08:46 PM
04/26/10 08:46 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
You need a lot more parts! But to your point, and the advice you were given--you have to know when to use the power , and when to not. Thats not always easy. Buts its ALWAYS great knowing its there. You live in TEXAS! Don't you have LOTS of low populated, wide open spaces? Or a dragstrip? Build what YOU want!
[Re: Pacnorthcuda]
#681196
04/26/10 08:48 PM
04/26/10 08:48 PM
CurYellowBird
San Antonio, TX
Ha yeah we do. Unfortunately somewhere along the line we fell in line with California law where if you are caught exhibiting any sort of speed or racing, they arrest you and crush the car. Nearest drag strip being about a 3 hour drive.
Project War Bird:
GY3 Curious yellow
All original
Re: Young gun needing last generation advice
[Re: Dougsmopars]
#681202
04/26/10 10:17 PM
04/26/10 10:17 PM
Posts: 10,200 Someplace you aren't
SomeCarGuy
Leave it alone and work on restoring the rest of the car. There is ALWAYS something to fix/spend money on. ALWAYS.
I want my fair share
[Re: vancamp]
#681205
04/26/10 11:35 PM
04/26/10 11:35 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Some good advice here for sure. My car makes about what you are shooting for, as simply as a 440 can. That said, it is a pain to keep cool, and not fun for a cruise at all. I do like to take it for short street drives, and open it up once in a while on the street, but never street race. Usually the guys who want to street race me have 15 second cars. so it's not really an issue. I'm working on a 49 fargo truck, as my street rig. Closer to 350 hp, instead of 550, and much nicer to drive. Build what you want, but remember that the fast track car, and the fun cruiser comb is a really tough build, best left to strokers.
[Re: CurYellowBird]
#681206
04/27/10 12:17 AM
04/27/10 12:17 AM
DaytonaTurbo
Manitoba, Canada
With a supercharger you can have the best of both, mild cam for cruising and the power for when you need it! If you want to build for 550hp/torq, go with a set of edelbrock rpm or 440source heads and a piston with a compression height of 2.060 or taller. That way with some milling you can get an honest 10.5 compression which with that cam and pump gas will do what you want. Then a set of headers and a good intake like a holley street dominator or edelbrock rpm. Carb you'll want to step up to an 850 since you'll be revving it over 6000rpm. I say build the high-po street machine you want. Just stick with a carb that has a choke(tune the carb well, including the choke), recurve your distributor to setup your advance properly and run the right stall converter/gearing for your cam. That will help it be as driveable as possible.
[Re: dave571]
#681207
04/27/10 12:24 AM
04/27/10 12:24 AM
CurYellowBird
San Antonio, TX
My rule when I got this car was to keep the car as stock as possible (minus a cam) and keep my 1980 malibu the all out custom car. This way I can have a balance. Got the malibu as my first car, dad told me if I was going to learn how to drive and wreck my first car, it was going to be a chevy. Never happened but anyway, yeah from what I've heard from other older mopar guys is that the 4 speed is alot of fun (don't know why yet)and along with the stock AC it should be a lot of fun to drive. Hoping to get it restored within the next 3 years before my senior year of college. I really appreciate the input guys. I do see the good in keeping the car original, to a point, while improving little things. IE the drum to disc brake conversion in the front and a slightly larger cam. The big improvement will be if I decide to go with 440source aluminum heads. My dad is running a set of 516 heads that are full ported and rival the flow of the aluminums. He mentioned if he decides to go with aluminum heads, along with the 8:71 blower, he would sell me the 516's for cheap. As for the racetrack, I know which one your talking about. It's a helluva drive from Boerne,tx all the way out there. And last time the guy was a [Edited by Moparts - Family Friendly Site - Keep it clean] cause he didn't like the burnouts in my malibu. It was either too much or too little for him. This is the malibu and you can see the roadrunner covered in the background.
Project War Bird:
GY3 Curious yellow
All original
[Re: Jim_Lusk]
#681212
04/27/10 11:52 AM
04/27/10 11:52 AM
Posts: 708 Mechanic Falls, Maine
4BBodies
mopar addict
mopar addict
I'm sure there is a huge difference (to the Police) between a car guy out in the middle of knowhere spinning his rear tires, and 2 young idiots with ricer's or VW's street racing, where they (or bystanders) can get hurt or killed. Crush your car? Doubtful. A good Lawyer would eat that one up, the punishment doesn't fit the crime. I am willing to bet that the powers that be would be buying you/building you a new car. California sucks in so many ways anyhow, if you aren't happy with Texas copying there stupid laws, write a few letters and remind your elected officials who voted for them. Laws like this are overkill, and responsible car nuts don't need them. And I, for one, am tired of being over-regulated! Build what you want, and run it hard when you can!
[Re: 4BBodies]
#681213
04/27/10 12:23 PM
04/27/10 12:23 PM
Posts: 20,748 A collage of whims
topside
A collage of whims
Here's my opinion, and I should say that I've modified rare cars, restored rare cars, modified "normal" cars, and been around race cars, historical cars, etc for decades: Curious yellow 4-spd A/C Roadrunners are beyond rare, probably a single-digit amount were made. That means it's very valuable, and extremely cool in stock form. That body is also pretty heavy, and not even close to the best platform for the kind of performance you seem to be after. Stick the big motor in something else - earlier B-body or '67-up A-body - and it'll be easier on drivetrain parts and you'll have the best of both cars/worlds. And you'll have one of the rarer & cooler Roadrunners on the planet. Lumpy cams & A/C aren't very compatible anyway, and you'll find that the lumpy cam in your imagination won't be as driveable in real life stop-&-go driving. I learned long ago to make the hot rod the hot rod, and to maintain the rare stuff intact.
[Re: rabid scott]
#681215
04/27/10 01:08 PM
04/27/10 01:08 PM
Posts: 1,884 Tracy CA
rabid scott
"You're Where?"
"You're Where?"
Tracy CA
Oh, as far as hopping up your car, just do it if you want to! As some people get older their priorities change and many seem to loose the interest in what made these cars desirable: the raw power that puts you into the seat and pitches your machine sideways as you grab for second gear. That's why the muscle car even exists. They weren't always "investments". Do what you want, you only get one shot at being young and dumb. Time doesn't wait for anyone! When I was your age (I'm 30) I had already broken a lot parts, crashed a few cars, and had a lot of fun going really fast!!
[Re: Commando1]
#681218
04/27/10 02:56 PM
04/27/10 02:56 PM
CurYellowBird
San Antonio, TX
I'm not paying attention to how much money I'll be spending. I'll keep the receipts and what not, but don't ask me how much I've already pissed away on my malibu lol. With the 383, after messing with comp cams camquest, I get the best power out of the PP280 .474/.474 camshaft. It gives me roughly 460hp/450lb. with decent heads. I'm not the young and dumb type. I like building cars right the first time and not half a**ing a build. As for making the owner watch as they crush your car, supposedly that is what they are doing down here. Luckily I know all the san antonio cops and all of them are hot rodders
Project War Bird:
GY3 Curious yellow
All original
[Re: CurYellowBird]
#681222
04/27/10 05:08 PM
04/27/10 05:08 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
...don't ask me how much I've already pissed away on my malibu lol.
Well, you've asked the wrong people if you should throw your money at a Mopar or some other brand...
It's way more fun in MoparLand.
[Re: Commando1]
#681223
04/27/10 06:03 PM
04/27/10 06:03 PM
CurYellowBird
San Antonio, TX
There isn't anymore money really going into the malibu since it is pretty much a done project. The only thing going on with it is a gasket rebuild on the engine since I've been driving it for five years. My old man is still giving me sh** about it cause he said "Most kids don't keep their first cars". Kinda funny my first car is a 80 malibu, second is a 71' Roadrunner, and third is my 96' Dakota.
There really is no point to selling it cause it is personalized to my taste and I probably wouldn't even get half of my money back out of it if I sold it. Its like back in the 80's when Dodge Darts and Plymouth Scamps weren't selling for a hundred bucks. Nowadays, people look at my old man and say "I can't believe you cut into a power bulge GTS hood". His response "So what? Nobody gave a damn when I did it anyway."
Project War Bird:
GY3 Curious yellow
All original
[Re: rapom]
#681225
04/27/10 08:54 PM
04/27/10 08:54 PM
dave571
Or thier first wife, or thier first dog etc.. My first car was a 73 duster. 340 car. I loved it, but I don't miss it one darn bit. Life is about change
[Re: RonaldV]
#681227
04/27/10 10:23 PM
04/27/10 10:23 PM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
Not my first car but my second one is still with me. 78 Trans Am bought in 82'. As per the OP, I would think seriously about modding the car too much. I modded my 69 Bee because there was no data plate or build sheet. Your car is a pretty rare car but it is yours to do as you please.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
[Re: dave571]
#681228
04/27/10 10:24 PM
04/27/10 10:24 PM
Posts: 242 midwest
intragration
midwest
I don't know about that... Life is about doing what you enjoy, be it change or more of the same. I still have my second car, '74 'Cuda which I bought in 1988 when my first car, a '70 Swinger, got smashed. I'd probably still have IT if it hadn't been t-boned at high speed by a Benz 560.
As far as performance, I think it's possible to have "enough" performance without compromising drivability and reliability. I base that exclusively on the fact that, as drivability goes down, so does the street fun factor, so you've gotta find the happy medium for you.
[Re: intragration]
#681229
04/27/10 10:50 PM
04/27/10 10:50 PM
CurYellowBird
San Antonio, TX
I pretty much screwed myself when I first got the car cause I knew exactly where the 440 was and paid 225$ for the complete long block out of a 78' winnebago. It wasn't until a few months later did I realize how rare and complete the car is. So now I have the option of doing a complete restoration with leaving the car she came, OR doing a 550hp/550lb. 440 build. I have all the parts to do either one.
But I think I'm going to just do a cam and head swap on the original 383, get the compression up, and go with the MP .474/.474 cam as comp cams suggested that cam would give me a 460hp/450lb combo. That will pretty much leave the car stock in a sense and I'll leave all my customizing thoughts towards the malibu.
Project War Bird:
GY3 Curious yellow
All original
[Re: stumpy]
#681231
04/28/10 12:49 AM
04/28/10 12:49 AM
DaytonaTurbo
Manitoba, Canada
Restore the car to stock, but build the drivetrain the way you want it. You can always stuff the original motor under your work bench in case some day you want it back.
You can build for power and still have something that's very driveable. I know with 10.5:1 compression 440, 440source stealth or edelbrock rpm heads, rpm intake and headers with a comp xe275hl cam you can make 500hp/550torq, proven several times by mopar mags and some members here. I've got a lunati voodoo cam in my 7.8:1 smogger 440 with 440source heads. That cam has slightly less duration to it than the comp 275, amd I mean slightly less at 4* less duration @050 on the intake and exhaust. And I'm running a whole lot less compression and on the street it drives about the same as it did when I had the stock lo-po 440 cam and stock heads in there. So with a bunch more compression and 4* more cam duration, throttle response on the street should be crisp if your carb and ignition advance are dialed in right.
With a modern cam design and decent flowing heads you can build a lot of power and still have something that runs great on the street. It's not like the old days where you're loafing around town with an outdated mopar 509 hydraulic cam.
