340 HP exhaust manifold installation ? #68118
06/05/08 05:01 PM
06/05/08 05:01 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
I am installing the 340 HP exhaust manifolds on my 1970 Challenger. The factory service manual says not to install the conical washers on the center ports for each side. If I put a washer on the center port bolts there is only about 3/8 of threads to engage the head. I purchased a reproduction bolt set so this leaves me with four extra conical washers. Is this correct?
Re: 340 HP exhaust manifold installation ? [Re: sbcjd] #68119
06/05/08 10:11 PM
06/05/08 10:11 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
i used the washers on the end studs only
Re: 340 HP exhaust manifold installation ? [Re: AARCONV] #68120
06/05/08 10:23 PM
06/05/08 10:23 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
They only go on the ends, where the studs are. I even use them back on headers!
Re: 340 HP exhaust manifold installation ? [Re: JDMopar] #68121
06/05/08 10:31 PM
06/05/08 10:31 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Yes, ends only. Keep the extras as spares.
Re: 340 HP exhaust manifold installation ? [Re: 69Cuda340S] #68122
06/05/08 10:35 PM
06/05/08 10:35 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
OK, thanks for the info.
Re: 340 HP exhaust manifold installation ? [Re: sbcjd] #68123
06/05/08 11:10 PM
06/05/08 11:10 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Just did a 71 340 Duster and used the washers on all the bolts and studs. The reproduction bolts are 1/2" shorter than the factory bolts! I used the originals because they were in good shape and everything worked out well.
JB Rhinehart, Realist
A-Body's RULE!
