98 avenger 2.0 m/t fluid change Mobil 5w30 #68006
06/05/08 12:08 PM
06/05/08 12:08 PM
Minnesota
skep419 Offline OP
skep419  Offline OP
Minnesota
i was just told that i should use mobil 1 synthetic 5w30 for transmission fluid. Is this a good idea
Re: 98 avenger 2.0 m/t fluid change Mobil 5w30 [Re: skep419] #68007
06/05/08 12:13 PM
06/05/08 12:13 PM
Saskatoon Sk, Canada
Mark340A66 Offline
mopar addict
Mark340A66  Offline
mopar addict
I've run synthetic ATF-4 in my 03 R/T due to the cold temps in winter. Check your owners manual, I'm not sure the Mobil 1 engine oil would be correct. These trans don't have the clash problems the old A833 had witb synth, synchros designed for it!
Mopar or No Car: Sold Nov/06 1970 Challenger 340 4bbl (A66 code), A833 4 speed, 3.23 SureGrip all numbers match. 03 Dodge SX 2.0 R/T 2.0L HO(CDN Neon R/T) Black w/Grey Leather, Sunroof
Re: 98 avenger 2.0 m/t fluid change Mobil 5w30 [Re: Mark340A66] #68008
06/05/08 12:18 PM
06/05/08 12:18 PM
Minnesota
skep419 Offline OP
skep419  Offline OP
Minnesota
it sais to use ms9417
Re: 98 avenger 2.0 m/t fluid change Mobil 5w30 [Re: skep419] #68009
06/05/08 03:22 PM
06/05/08 03:22 PM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
Amsoil recommends their Manual Synchromesh Transmission Fluid 5W-30.
Trans fluids.
To find the right fluid for your vehicle, check out the online product application guide Here.
