Cal Tracs..base setting? #678606
04/24/10 01:17 AM
04/24/10 01:17 AM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Lost the instructions along time ago...
What is the base setting for Cal Tracs?
Thanks!
Re: Cal Tracs..base setting? [Re: cudadoug] #678607
04/24/10 04:53 AM
04/24/10 04:53 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Set the drivers side with enough clearence on the roller.aprox .050/.100.Set the passenger side with the roller just touching the spring and one or two flats of preload at ride height and race weight.
Re: Cal Tracs..base setting? [Re: B G Racing] #678608
04/24/10 11:50 AM
04/24/10 11:50 AM
cudadoug Offline OP
cudadoug  Offline OP
Thank you BG!
