1970 Duster 340 Fuseblock pics #67526
06/04/08 04:54 PM
06/04/08 04:54 PM
Indiana
W5Duster436 Offline OP
Indiana
Anybody have pics of a 70 duster fuseblock with good stenciling? don't know if the 340 rallye gauge cars are different but I need to see what size amp fuses go in it because my stenciling is almost non-existent.
Thanks in advance!
Re: 1970 Duster 340 Fuseblock pics [Re: W5Duster436] #67527
06/04/08 05:35 PM
06/04/08 05:35 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I think the service manual has that info too.
Re: 1970 Duster 340 Fuseblock pics [Re: Dart 340] #67528
06/04/08 06:45 PM
06/04/08 06:45 PM
Indiana
Indiana
I couldn't find it hence looking for pics.
Re: 1970 Duster 340 Fuseblock pics [Re: W5Duster436] #67529
06/05/08 12:15 PM
06/05/08 12:15 PM
Indiana
Indiana
Nobody has a picture of the fuse block?
Re: 1970 Duster 340 Fuseblock pics [Re: W5Duster436] #67530
06/05/08 12:29 PM
06/05/08 12:29 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I can take one of mine, but won't be until tonight.
Which fuse is blown?
Re: 1970 Duster 340 Fuseblock pics [Re: Dart 340] #67531
06/05/08 12:35 PM
06/05/08 12:35 PM
Indiana
Indiana
The car was in pieces when I bought it and had been sitting since '79. the fusebox stenciling is pretty much non-existent and no fuses were in it.
I don't know if std. fuse block is different from the rally gauge fuse block though. Picture or simple text from left to right etc. showing what is what and what amp fuse to put in would suffice. thanks!
Re: 1970 Duster 340 Fuseblock pics [Re: W5Duster436] #67532
06/05/08 12:39 PM
06/05/08 12:39 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I looked in the cars and don't have one loose here. I have to go to storage and think I have one out of the car. I'll get a crappy pic of it later today.
Re: 1970 Duster 340 Fuseblock pics [Re: RobX4406] #67533
06/05/08 12:57 PM
06/05/08 12:57 PM
Indiana
Indiana
Rob at $4 a gallon don't go make a special trip..
Re: 1970 Duster 340 Fuseblock pics [Re: W5Duster436] #67534
06/05/08 01:29 PM
06/05/08 01:29 PM
RobX4406 Offline
RobX4406  Offline
No special trip. I got yelled at the other day because there are two huge boxes in the living room. Those have to go to storage anyways.
Send me the medallion dimensions again. I've been hammered with stuff recently.
Re: 1970 Duster 340 Fuseblock pics [Re: RobX4406] #67535
06/05/08 02:10 PM
06/05/08 02:10 PM
Indiana
Indiana
Seemed like they were about 3/8" wide on the ends and just slightly wider in the middle and about 2" tall. I had someone send me a set from a roadrunner that were the same but about 1/2" taller and I already sent them to the upholstery shop. I have about 3 weeks though so if you have them let me know asap and I can get them to the upholstery shop.
I'll have a look at my post and see if I put dimensions in there.
Re: 1970 Duster 340 Fuseblock pics [Re: W5Duster436] #67536
06/05/08 03:20 PM
06/05/08 03:20 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
My '70 Duster block is laid out like this - starting from the end where the harness enters the block:
3A INST LPS
20A TAIL LP C-LTR
20A DOME-STOP E/FLASH
20A RADIO B/UP
20A A/C HEAT
20A ACC ACC (Empty, not used)
Also attached a diagram just for grins.
Re: 1970 Duster 340 Fuseblock pics [Re: 70Duster440] #67537
06/05/08 07:49 PM
06/05/08 07:49 PM
Indiana
Indiana
3A INST LPS
20A TAIL LP C-LTR
20A RADIO B/UP
20A A/C HEAT
So looking at the fuse block from the front the 3A goes in the far left slot? Thanks!
