Fenderwell Access Cover Plate Bolts? #67452
06/04/08 02:15 PM
06/04/08 02:15 PM
Anonymous OP
Anonymous OP
Hello,
Was wondering if anyone knew the correct bolts (or metal screws?) that were used to attach the fenderwell access cover plates (which are removed for alignments)? This is for a 70 Challenger.
Mine were missing since I've owned the car so I'm not aware of what fasteners were used for these.
Thanks!
Re: Fenderwell Access Cover Plate Bolts? #67453
06/04/08 04:38 PM
06/04/08 04:38 PM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
Contact Tom at R/T Specialities. He has them in stock
Re: Fenderwell Access Cover Plate Bolts? [Re: TrueTripleX] #67454
06/05/08 09:47 AM
06/05/08 09:47 AM
Anonymous OP
Anonymous OP
Ok, Thanks! I found these bolts on his site. But it doesn't look like there are nuts for these.
Does anyone have a picture of how these access covers look when installed? I've only seen the holes in my fender since I've had this car.... never seen the access covers mounted.
Thanks!
Re: Fenderwell Access Cover Plate Bolts? #67455
06/05/08 04:48 PM
06/05/08 04:48 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
it's a #10 hex head screw that threads into the sheetmetal. no nut required
