For the multiple carb users out there
#672318
04/17/10 06:57 AM
04/17/10 06:57 AM
Posts: 5,890 Athens, Greece
Pyper70
Athens, Greece
Do I need to run a return fuel line to the tank?
I have a 440 with Dual Quads in the works. I have two 500cfm's and I am upgrading from the stock carter pump to the Street pump which is listed at 110gph. Where exactly do I put the return line? I have a Russell union -6AN x -6AN (my fuel line from Carbs to pre-filter is a -6AN, then from pre-filter to fuel pump is a 3/8"NPT hardline) On that union mentioned above there is a threaded port for what looks to be a fuel pressure gauge. I already have a pressure gauge further up the fuel line. If I have to install a return line, can I use the 1/8"NPT port?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: For the multiple carb users out there
[Re: Pyper70]
#672319
04/17/10 07:08 AM
04/17/10 07:08 AM
i use a product engineering regulator and there return kit, high and low port is used for the return, heres mine.
[Re: NV69B7RR]
#672322
04/19/10 08:11 AM
04/19/10 08:11 AM
Pyper70
Athens, Greece
I assume to help with vapor lock and there is no way 110gallons per hour could be used on my motor, The extra fuel has to go somewhere. I prefer it to go back to the gas tank and not rupture a line
