2.94s vs 3.55s vs 4.10s #672285
04/17/10 04:09 AM
04/17/10 04:09 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Right now I have 2.94s in my Satellite. Its a stock 350 horse 440, runs good, headers and a Holley 770 carb. I'm going to change the cam to something mild, probably the bigger Summit cam, in a few weeks and put an Eddy RPM on it. Right now the car has 2.94 gears and well, it feels like it has 2.94 gears in it.
I have a 2.94 sure grip, 741 case and a buddy has a 3.55 open 741 case. I can buy the 3.55 open from him and swap my sure grip to the 3.55 and have 3.55 gears but I'm debating weather or not to just put 4.10s in it. The tires will be 28 inches tall. Im a strong believer in what the factory engineers do and the quickest street car Mopar ever put together is an A12 car and they ALL came with 4.10s. I dont go faster than 60 on the highway anyway and usually like to take the Satellite the long way everyplace.
How do you guys feel about 3.55s vs 4.10s? Does it pull much harder?
Re: 2.94s vs 3.55s vs 4.10s [Re: GTX MATT] #672286
04/17/10 07:45 AM
04/17/10 07:45 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Most performance package cars I thought came with 3.91's. All things being equal I'd pick the 4.10's. If I were given 3.55's I'd go with them vs. paying to install 4.10's the gain isn't worth it.
Re: 2.94s vs 3.55s vs 4.10s [Re: redraptor] #672287
04/17/10 08:19 AM
04/17/10 08:19 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I second the 3.55's, good all around gear. I went from 2.96's to 3.55's and liked it.
Re: 2.94s vs 3.55s vs 4.10s [Re: GTX MATT] #672288
04/17/10 10:41 AM
04/17/10 10:41 AM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Do you have a 727 or 833? If it's a 727 and you plan on running a small hyd cam I would go with 3.55's, if it's a 833 I would run 4.10's and get a small solid like a MP284/.528.
I don't think the summit cam is large enough to run with 4.10's and a 440, I have a similar cam in my 318 with 4.10's and it seems like a good match.
Re: 2.94s vs 3.55s vs 4.10s [Re: MoparJoe] #672289
04/17/10 10:46 AM
04/17/10 10:46 AM
Clinton Twp, Michigan
DerickS Offline
DerickS  Offline
4.10's for the kick in the pants feel, if you never go over 60mph its worth it. Even if you did get on the E way you wont even be turning 3000 RPM. My personal choice would be 3.91's, my dads 68 R/T with a stock 440 Mag loved the 3.91 compared to its orig 3.23's.
Re: 2.94s vs 3.55s vs 4.10s [Re: DerickS] #672290
04/17/10 11:09 AM
04/17/10 11:09 AM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
Sorry to off topic this post, but wow the Red Duster in the above post takes me back to my high school days. I had a Yellow with black stripe 74 Duster 360. I had the same molded hood scoop and all. Ok, sorry for the interruption, it was just one of those flashbacks.
Re: 2.94s vs 3.55s vs 4.10s [Re: DerickS] #672291
04/17/10 11:11 AM
04/17/10 11:11 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Be honest with yourself- If you are not gonna do alot of highway driving then go with the 4:10s. I had 29" tall tires with 4:10s and when I would get on the highway I was always bumping the B&M shifter thinking was in second when I was already in 3rd. Your 440 if it is a true 350 horse version is a torque freak and the 3:55s are a nice all around gear!
Keep old mopars alive.
Re: 2.94s vs 3.55s vs 4.10s [Re: 2boltmain] #672292
04/17/10 11:47 AM
04/17/10 11:47 AM
Long Island, NY.
Stroked65Belv Offline
Long Island, NY.
Go with the 3.55, your gonna love it on the highway. With the 4.10 over time your going to realize you cant go for that ride at 70-75 mph and see that tach screaming!
Re: 2.94s vs 3.55s vs 4.10s [Re: Stroked65Belv] #672293
04/17/10 12:29 PM
04/17/10 12:29 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Even 3.55's aren't great on the highway. 65mph is basically 3000rpm with a 28" tire. 4.10's will spin even higher. You can play with this calculator:
http://vexer.com/automotive-tools/speed-rpm-calculator
If you do an overdrive trans or zero highway driving, 4.10's are great.
Re: 2.94s vs 3.55s vs 4.10s [Re: DaytonaTurbo] #672294
04/17/10 01:00 PM
04/17/10 01:00 PM
Kirkland, Washington
Pacnorthcuda Offline
Given THOSE choices...3.55 no brainer. Now based on your description of the use of the car, if you could get a set of 3.73 or 3.91's then there would be a little harder decision to make...
Re: 2.94s vs 3.55s vs 4.10s [Re: GTX MATT] #672295
04/17/10 01:23 PM
04/17/10 01:23 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I would say 355 max. I ran 323's on a 67 satellite, 440, 474 cam, headers and ran 13.40's at strip.
Re: 2.94s vs 3.55s vs 4.10s [Re: buildanother] #672296
04/17/10 01:34 PM
04/17/10 01:34 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
3.23-3.55 gears are great with a 4 speed 440. Let the 440 3.75 stroke pull you ahead with a large, lasting, broad piston flamefront.
Peronally using 3.23's in my 4spd cuda, In my 4 door 4 spd valiant too.
The factory 440 peaked out before 5k rpm , no sense in going with a 4.10. If you had a cammed 318 and wanted to zip around, have your way with the 4.10s.
Re: 2.94s vs 3.55s vs 4.10s [Re: Stroked65Belv] #672297
04/17/10 02:39 PM
04/17/10 02:39 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I hated 3.55's on the highway. with 27" tall tires it's 3300 RPM at freeway speeds (70-75 in MI)
2017 Grand Cherokee Overland
Re: 2.94s vs 3.55s vs 4.10s [Re: patrick] #672298
04/17/10 08:35 PM
04/17/10 08:35 PM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
I've got an A12 Bee with 4.10s, 833 and large summit cam(defunct General Kinetics, Camshaft merchandisers "P" series grind)
. Great for laying rubber , but stinks on the highway. It sucks having KIAs and Hondas zinging by at 70-75 while the Bee screams along at 55. Been thinkin of changing out the dana for a 8 3/4 with 3.23s
Re: 2.94s vs 3.55s vs 4.10s [Re: 6PACMAC] #672299
04/17/10 08:46 PM
04/17/10 08:46 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
i love the 3;55 gear. Mine's a 440 auto 28.5 tire. No problem running 70 80 on the highway and no Kia or Civic is gonna blow your doors off. Had 3:91's in a 4 speed car that was also excellent.
Re: 2.94s vs 3.55s vs 4.10s [Re: Dougsmopars] #672300
04/17/10 08:56 PM
04/17/10 08:56 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
I'd go 3:73 if your gonna buy new gears.
Re: 2.94s vs 3.55s vs 4.10s [Re: GTX MATT] #672301
04/18/10 01:40 AM
04/18/10 01:40 AM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
3.55's, stick or auto, works well. If you want to be ultra conservative, 3.23's aren't too bad. It
is all about where and how you drive!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 2.94s vs 3.55s vs 4.10s [Re: HYPER8oSoNic] #672302
04/18/10 12:03 PM
04/18/10 12:03 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
If I made a small step change from 3.23 to 3.55 and GOT PLENTY HAPPY I can guess a bigger change up to 3.55 will get more happiness.
I could get 100-110 miles on little bit less than 4K RPMs ( in D ). 27" tires.
but for all around use I woulnd't go higher than 3.55
