no dash lites #67134
06/04/08 12:02 AM
06/04/08 12:02 AM
az
stage3 Offline OP
stage3  Offline OP
az
OK,you guys helped before so lets try again! I recently purchased an 80 Chrysler lebaron that has
no lites illuminating on the main instrument cluster. Lites work for the heater/ac panel and radio. Headlite switch works fine in all positions
even dimmer for dash lites which only work above mentioned heater/radio panels. I know it is something simple, just not familiar with these cars. Again, thanks in advance for any help!!!
Re: no dash lites [Re: stage3] #67135
06/04/08 12:33 AM
06/04/08 12:33 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Sounds like a bad ground on the instrument cluster circuit board. I would say change the bulbs, but odds are not good they would all fail at the exact same time.
