Steering boxes #67007
06/03/08 12:37 AM
06/03/08 12:37 AM
Texas
3
340 Dart Offline OP
340 Dart  Offline OP
Texas
I have a 74 Duster I want to put a manual steering box in.
I have found a couple of B and E body boxes close to me and I think they will bolt up but are the splines the same?
66 Dart GT 74 Duster
Re: Steering boxes [Re: 340 Dart] #67008
06/03/08 01:33 AM
06/03/08 01:33 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the manual steering box will fit.
two things needed,,
one....the power steering shaft is shorter then the manual steering shaft also the splines are not the same... can get adapter from flaming river to make it work... or get manual steering column shaft..
two..you will need a new pitman arm..the 73 and larger will have a larger diameter spline then the manual steering boxes...get a manual steering pitman arm for 73 and later A body...
Tony
70 AARCuda Vitamin C
Re: Steering boxes [Re: 70AARcuda] #67009
06/04/08 12:52 AM
06/04/08 12:52 AM
Seattle WA
RichV Offline
RichV  Offline
Seattle WA
Or you can get a large spline manual box out of a van.
Re: Steering boxes [Re: RichV] #67010
06/04/08 01:40 AM
06/04/08 01:40 AM
Texas
3
340 Dart Offline OP
340 Dart  Offline OP
Texas
Thank you both very much!
