Re-torque mains and rods after storage? #66956
06/02/08 10:56 PM
06/02/08 10:56 PM
Snowing in the north!
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Having a few issues with an engine I bought that was
in storage for a few (5) years. the cam bolt came loose and wiped out the key etc. Thoughts on pulling
the pan and re-torqueign the rods and mains?
Re: Re-torque mains and rods after storage? [Re: Dart 340] #66957
06/02/08 11:09 PM
06/02/08 11:09 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
cam bolt came loose from never being properly installed
Re: Re-torque mains and rods after storage? [Re: 05dakota] #66958
06/02/08 11:14 PM
06/02/08 11:14 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Yes I know. Just makes me wonder what the heck else is wrong. Can you re-torque without issues?
Re: Re-torque mains and rods after storage? [Re: Dart 340] #66959
06/06/08 12:09 PM
06/06/08 12:09 PM
dogdays Offline
dogdays  Offline
Just do it. No issues unless you start taking things apart and swapping them.
R.
Re: Re-torque mains and rods after storage? [Re: dogdays] #66960
06/06/08 01:36 PM
06/06/08 01:36 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
The one issue would be thread lube. Moly lube will allow the correct stretch with less torque. Oil will take more torque.
If the engine was built with moly/arp lube on the threads and you torque them to oil specs thinking they are loose you will overstretch them.
I think its pretty obvious to tell what was used even if you have to take a bolt/nut off.
Also keep in mind that a fastener will take more torque to break free, so the proper way to retorue is to back off a hair and run it back up letting the wrench get to the torque spec during one constant movement.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
