o2 sensor position
#669551
04/14/10 12:59 PM
04/14/10 12:59 PM
Posts: 2,915 A shed in England
Tig
A shed in England
How much collector will I need to ensure accurate O2 readings? At the moment collector is 7 inches long, too short I fear. TIA
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: o2 sensor position
[Re: supercomp]
#669553
04/14/10 02:33 PM
04/14/10 02:33 PM
Tig
A shed in England
We get more accurate readings with it in a tube about 18" from exhaust port.
Unfortunately lack of clearance dictates that I cannot mount the sensor in the actual header pipe. I'm just wondering how far from the open collector end can it be before readings will be inaccurate? thanks for your reply
[Re: Tig]
#669554
04/14/10 09:09 PM
04/14/10 09:09 PM
8-10" is acceptable any closer and you get false readings.
[Re: Tig]
#669555
04/14/10 11:04 PM
04/14/10 11:04 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would add extensions to your collectors you could use them anyways then put them in about 4" - 6" from the end of the primaries... about 10 o'clock or 3 o'clock so you dont get water in them.... if you have a evac make sure you put them in before the evac... the evac will give you a false reading
[Re: Grizzly]
#669557
04/15/10 04:02 AM
04/15/10 04:02 AM
Posts: 520 New Zealand
nz383man
New Zealand
From the NGK AFX manual
AFX Installation Below are recommended guidelines for installing the AFR sensor. Some exhaust configurations may make it difficult to meet each of the recommendations exactly, and some compromise in mounting may be required. The sensor does not necessarily have to precisely meet every mounting guideline below to operate, but please understand that the better you conform to these rules, the longer the sensor will last and the more accurate the results will be. The AFR sensor should be located between 12” and 48” from the engine, upstream of any catalyst device if so equipped. The closer the sensor is to the engine, the more likely it will be overheated, possibly shortening its life. The further it is from the engine, the more likely condensed water will get into the sensor and thermally shock it, again possibly shortening its life. The sensor should be mounted at least ten exhaust diameters upstream of the exhaust exit (ex. for a 3” exhaust pipe, that is 30”). If the sensor is mounted between one and ten exhaust diameters from the exhaust exit, the AFR measured will be leaner than the actual AFR by as much as 2 AFR at low engine speeds (i.e. less than 3000 rpm). Make sure there are no leaks in the exhaust system, as this will create an artificially lean (higher) AFR reading. Also, install the sensor upstream of any factory air-injection if so equipped, as this too will cause a false lean reading.
[Re: blownzoom440]
#669560
04/16/10 01:17 PM
04/16/10 01:17 PM
Tig
A shed in England
Thanks for the reply's guys I'll fab up some 18 inch extensions, trickey 'cause of the 'box crossmember. Mainly used for WOT ratio's at the track. The rest I can set / monitor on the street as I have a full system. Thanks again
