which rear main seal for magnum motor? #668782
04/13/10 11:58 AM
04/13/10 11:58 AM
Costa Mesa, CA
chache876 Offline OP
Costa Mesa, CA
Is there a difference between rear main seals on Magnum motors versus the older LA motors? I have a 5.9l magnum I need to replace it on...or is one better than the other?
Re: which rear main seal for magnum motor? [Re: chache876] #668783
04/13/10 12:49 PM
04/13/10 12:49 PM
Andrewh Offline
Andrewh  Offline
If you are using a mag oil pan, use the mag one piece. Otherwise you need to use the la gaskets with the la pan
Re: which rear main seal for magnum motor? [Re: chache876] #668784
04/13/10 12:53 PM
04/13/10 12:53 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
The Magnum rear main seals are the same 2 piece design as the earlier LA motors. Make sure to buy a quality Fluoroelastomer (Viton) seal.
I offer these through my distributors on here as #9360 for the 5.9L (360) Magnum.
