Neutral safety switch issues - starts in gear
#668246
04/12/10 05:15 PM
04/12/10 05:15 PM
Posts: 84 NC
Badfish67
NC
So I have a new starter relay, a new neutral safety switch in the transmission (single wire), ran all new wires from the switch to the relay, relay to the starter button, and it still starts in any gear. Anyone have any ideas???
1967 Barracuda
360ci/727
9.723ET @139.44mph
Re: Neutral safety switch issues - starts in gear
[Re: superwrench]
#668250
04/12/10 06:13 PM
04/12/10 06:13 PM
Posts: 84 NC
Badfish67
NC
I'm not sure what lever is in the transmission...I will need to call John Cope and ask. I tried the test light and got no light any way I tried it.
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: superwrench]
#668251
04/12/10 06:35 PM
04/12/10 06:35 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The single post NSS will work just fine with the newer roostercomb.
A simple test with a meter or test light will show if the NSS is staying grounded in gears other than P and N.
[Re: John_Kunkel]
#668252
04/12/10 07:38 PM
04/12/10 07:38 PM
Posts: 84 NC
Badfish67
NC
So I put the test light on the NSS and I dont get a light in any gear...but it will still start in all gears.
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: stumpy]
#668254
04/12/10 09:31 PM
04/12/10 09:31 PM
Posts: 84 NC
Badfish67
NC
With the test light hooked up I can touch the outside of the NSS and I get a light, but no light on the terminal where the wire hooks up to.
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: 52savoy]
#668257
04/13/10 08:30 AM
04/13/10 08:30 AM
Posts: 84 NC
Badfish67
NC
I have the switch thats in the middle of the pictue. So the car will still start with the NSS disconnected. It just seems like my wiring is bypassing the starter relay. I have the wire going from the NSS to the G on the relay, then a wire from the I on the relay to my starter button. What else am I missing???
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: stumpy]
#668259
04/13/10 10:58 AM
04/13/10 10:58 AM
Posts: 84 NC
Badfish67
NC
Thats what I thought too...so I got a new starter relay and ran a new wire from the NSS to the starter relay...same issues...
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: 52savoy]
#668262
04/13/10 01:30 PM
04/13/10 01:30 PM
Posts: 84 NC
Badfish67
NC
I guess thats my next step...Thanks all!!!
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: Badfish67]
#668263
04/13/10 04:24 PM
04/13/10 04:24 PM
John_Kunkel
Rio Linda, CA
Don't bother pulling the pan, if "the car will still start with the NSS disconnected" as you stated earlier the problem isn't in the transmission.
[Re: John_Kunkel]
#668264
04/13/10 06:24 PM
04/13/10 06:24 PM
Posts: 6,089 Valencia, España
NachoRT74
Valencia, España
unplug the wire at starter relay and if doesn't crank, I think you found it wire is simply grounded somehow, peeled or whatever...
