Re: Neutral safety switch issues - starts in gear
[Re: stumpy]
#668266
04/13/10 06:46 PM
04/13/10 06:46 PM
Posts: 6,089 Valencia, España
NachoRT74
Valencia, España
yea I read that, but if cranks without the wire plugged, is still starter relay related... if doesn't crank with wire unplugged at relay, then is still the wire... no other posibility that I'm aware at least
( both test with NSS unplugged )
[Re: stumpy]
#668268
04/13/10 10:25 PM
04/13/10 10:25 PM
Posts: 84 NC
Badfish67
NC
It will crank with the wire plugging in or not and in any gear. I'm thinking that somehow i'm bypassing the NSS...any ideas about that? I have a 6 switch Painless Wiring box. The "I" wire from the starter relay goes to the starter button in the Painless box and the other wire from the NSS goes to the "G" on the starter relay. Thats about it...
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: stumpy]
#668270
04/14/10 01:49 AM
04/14/10 01:49 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
This whole scenerio defies all logic regarding a NSS and/or the relay!! The ONLY engineered way the starter can get juice is if the relay grounds . The only other way is if the middle wire on the relay (the one that goes to the starter solenoid small terminal)gets 12 volts. If there's no wire on the ground (G) side of the relay, then that tells me the relay is continuosly grounded. Yet a new relay doesn't fix the problem!! Something is REALLY strange.
