Handling upgrades for Challenger #66705
05/31/08 03:19 PM
05/31/08 03:19 PM
MD
RTSE4ME Online content OP
RTSE4ME  Online Content OP
MD
Here is what has been done so far......
Front:
Firm feel Stage3 box with fast ratio arms
Firm Feel UCAs
1" torsion bars
Moog 11/16 tie rods
QA1 shocks
Stock sway bar
AndyFs viper brake kit with Hydraboost
Rear:
Original Leaf Springs
Edelbrock shocks
DrDiff offset hangers with 69 b-body dana60
drum brakes
Tires: Front 245/45/17 Rear 275/50/17.
Alignment specs:
Caster +3.5
Camber -.5
Toe 1/32
What should be my next step? sway bars? rear springs?
Are the adjustable struts from RMS worth it? I have budget of $500.
Re: Handling upgrades for Challenger [Re: RTSE4ME] #66706
05/31/08 03:30 PM
05/31/08 03:30 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I would get Koni's or QA1's for the rear and call it a day. You did a really similar build up to my car, how does it perform ?
I have..
MP 1.22" bars
FF Stage 4 'secret' box...a little firmer than the normal 3.
Konis front and rear Full 3 on front, 1.5 on rear.
Braced stock LCA's
Moog 9/16" tie rods, (I thought I got 11/16" but I mis ordered)
Poly bushings with reg Moog BJ's
CAP Tubular upper control arms
stock 15/16" front sway bar with Energy Suspension greaseable bushings
stock struts with Prothane bushings
stock rear leafs
Addco 7/8" rear bar
Yokohamas in 255/60/15 in front and 275/60/15 in rear
11.75" discs with Firm Feel Carbon metallic pads and MP alum MC in 1.125" stock 11" drums in the rear and I will put the FF shoes back there too.
I'm going to drop the ride height all around a little more, and align it soon. I hope for a really good performing combo, and when the tires are done for I will put a set of 17's on it and really tear it up.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Handling upgrades for Challenger [Re: RTSE4ME] #66707
05/31/08 03:38 PM
05/31/08 03:38 PM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
Frame conectors , torque boxes , front shock tower braces reinforced K frame etc. Some of the biggest gains are from a ridgid body and frame .
Re: Handling upgrades for Challenger [Re: pro451bee] #66708
05/31/08 03:40 PM
05/31/08 03:40 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I have frame connectors ready to go in also, and I might buy the XV Fender Brace too..
I think their radiator support and fender braces would be a good investment, but I just want to stick with bolt ons for now.
Re: Handling upgrades for Challenger [Re: AlexP] #66709
05/31/08 04:00 PM
05/31/08 04:00 PM
MD
MD
The car handles pretty well. I can drive it as I would a late model sedan since I improved the handling and braking. Just gives you more confidence taking a hiway off ramp.
I was thinking of getting some of the US or XV frame connectors and some torque boxes. I wouldn't mind getting the XV front shock tower brace but I just dont it see it fitting in my car with a RB.
Re: Handling upgrades for Challenger [Re: RTSE4ME] #66710
05/31/08 04:14 PM
05/31/08 04:14 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Front:
Firm Feel UCAs
1" torsion bars
Moog 11/16 tie rods
QA1 shocks
Stock sway bar
Rear:
Edelbrock shocks
drum brakes
Alignment specs:
Caster +3.5
Camber -.5
Toe 1/32
A 1 1/8 front sway bar first, the $99 ebay ones will do fine for this car since it allready has a sway bar. Next I agree, I'd do Frame connectors. After that, torque boxes. But if you're allready welding in the frame connectors maybe do this at the same time.
You've got the the alignment where you want it, so no need for adjustable struts.
Then if you have any money left go out on a track day and have some fun driving it. You have done a bunch, now go out and play !! Stop messing around with it any more until you get it sorted out on the track.
Re: Handling upgrades for Challenger [Re: autoxcuda] #66711
06/02/08 04:44 PM
06/02/08 04:44 PM
Melbourne, FL
dwbiggs Offline
super gas
dwbiggs  Offline
super gas
Melbourne, FL
If you don't mind...what machine did they use on your alignment? I couldn't get my caster done because of clearance issues. I have my front end lowered a bit and have 17" wheels as you do.
Re: Handling upgrades for Challenger [Re: RTSE4ME] #66712
06/02/08 05:21 PM
06/02/08 05:21 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
Very similar to the set-up I've got, however, I've got the 1 1/8 front sway bar, and a 1"(i think) rear sway bar.
I've only got 14" rims too...I'll probably end up going with just some good 15" rims w" 245-265 series tires.
I've still got to upgrade the brakes, 4 wheel drums.
I've got the upgraded front torsion bars too.
I'll probably also look for frame connectors in the future too.
I'll tell you, nothing more fun than hitting the cloverleaf exits out by me
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: Handling upgrades for Challenger [Re: dwbiggs] #66713
06/02/08 07:46 PM
06/02/08 07:46 PM
MD
MD
I did the alignment with this..... Fastrax I borrowed a friends laser level to level out the car. For turn plates I used the weekly ad inserts that come in the Sunday paper. Something about the ink or paper they use makes them slippery and a good tape measure for toe.
It drives straight with no pulling and tire wear is even so I guess I got it close.
Since I usually change one thing at a time on my car, I figured the Fastrax would be a good investment.
Your welcome to borrow it if you want to try it out.
Re: Handling upgrades for Challenger [Re: autoxcuda] #66714
06/02/08 08:03 PM
06/02/08 08:03 PM
MD
MD
Anyone use the swarbar kits from Just Suspension? Looks like the price is right....$100 http://www.justsuspension.com/category/246
Don't think the rear would work since I have a B-body dana 60. I wonder if I could use a B-body rear kit? I could get the bars for $200 and the frame connectors for another $200. Which leaves me $100 for track day at Summit Point.
Re: Handling upgrades for Challenger [Re: autoxcuda] #66715
06/02/08 10:54 PM
06/02/08 10:54 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
What he said
Re: Handling upgrades for Challenger [Re: dwbiggs] #66716
06/03/08 12:20 AM
06/03/08 12:20 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
This one. I talked to them last week about how you couldn't get caster. The did say some alignment heads are old school and don't have an up and down adjustment.
