spring pressure for MP 509 cam #667107
04/11/10 06:54 PM
04/11/10 06:54 PM
New Jersey, USA
Y
yella71 Offline OP
yella71  Offline OP
Y
New Jersey, USA
Does anyone know what the pressures should be for the mopar 509 hyd? this would be 915 heads with stock valves.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: spring pressure for MP 509 cam [Re: yella71] #667108
04/11/10 07:07 PM
04/11/10 07:07 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: spring pressure for MP 509 cam [Re: Dodgem] #667109
04/11/10 08:01 PM
04/11/10 08:01 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i just used the factory recommended valve
#P5249848
in a 906 head
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: spring pressure for MP 509 cam [Re: yella71] #667110
04/11/10 08:09 PM
04/11/10 08:09 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I used the MP 933 spring myself, as it was the recomended spring back in the day by MP. Its numbers were 110 lbs @ 1.900 and 333 lbs @ 1,400
Back when I bought them they were advertised and both .510 lift and .520 lift. I used them at .542 lift with my 1.6 rockers. I now see Mancini lists .500 lift
In Hindsight I wouldnt buy them again as they limit you to your max lift.
For the same Money you can get a spring that will allow lifts up to .600+ and still get the pressures that will work great for that cam and allow you to grow to a bigger cam without having to buy new valve springs all over again. mike
