8.25" case modification #66641
05/31/08 01:34 PM
05/31/08 01:34 PM
Anonymous OP
Anonymous OP
Has anyone modified an 8.25" axle case with 2.45 gears to accept a larger ring gear (2.94+)? I've heard it can be done, but I'd like to hear some firsthand pointers before I go nuts with a grinder.
Re: 8.25" case modification #66642
05/31/08 02:58 PM
05/31/08 02:58 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I believe they made a spacer and longer bolts a few years ago. Don`t know if it is still available. Nothing to grind. Mike
Re: 8.25" case modification #66643
06/02/08 05:14 PM
06/02/08 05:14 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Are you talking about the axle case/housing (giant assembly) or the differential case? I think only the differential - the part the ring gear bolts to - needs to be swapped out. A sure grip diff for an 8.25 is probalby cheap enough to not worry about finding a spacer ring, at least in my book it would be.
Clair
