2.0 liter neon??? #66635
05/31/08 01:22 PM
05/31/08 01:22 PM
Hershey,PA
mracer360 Offline OP
Hershey,PA
My dad is working on a 97' that had the water pump lock up a blow the timing belt. Do neons have valve issues when this happens or do they have enough clearence???
Re: 2.0 liter neon??? [Re: mracer360] #66636
05/31/08 01:59 PM
05/31/08 01:59 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Nope, interference engine. Sometimes when this happens the valves are toast, other times people say they're still usable. The water pump/timing belt is a maintinance item on the neons and you should not just let it go until it dies because you could be looking at a costly fix depending on how bad things are hurt. Should really be done every 60-80k miles on an interference engine IMO.
You can either pull the head and check it out, or put a new t-belt and water pump in, then do a compression test on it and hope the results are acceptable.
Re: 2.0 liter neon??? [Re: DaytonaTurbo] #66637
05/31/08 03:28 PM
05/31/08 03:28 PM
PA
70Duster Offline
70Duster  Offline
PA
Not one of Chrysler's better ideas.....making an economy engine an interference engine. Even worse, the tensionrs and/or water pumps have been know to fail before the belt. When the tensioner fails, it takes out the belt which then destroys valves.
Re: 2.0 liter neon??? [Re: 70Duster] #66638
05/31/08 05:25 PM
05/31/08 05:25 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
My son had a '97 2.0 4 valve neon and lost the water pump. I installed 8 new intake valves, water pump and timing belt. Seems to me it was about $3-400 in parts. Not all the valves looked bad but they'd all kissed the pistons so they all got changed. Dave
