8 3/4 Question #66540
05/31/08 11:22 AM
05/31/08 11:22 AM
southern Idaho
moparcyco Offline OP
southern Idaho
Last weekend I pulled an 8 3/4 rear from a 68 belvedere 4 door I took the sure grip out for my Bee.So I thought the hosing and axles would be the same as what is in my Bee.But the housing is a 1/2 in shorter overall lenght and so are the axles.So is a belvedre a b-body I thoght all the 68 to 70s had the same size housings.Could someone shed some light on what I have here.The rear in my Bee measures 55 inches from the outside flange to outside flange no backing plates installed.The one from the belvedre is 54 1/2.
Re: 8 3/4 Question [Re: moparcyco] #66541
05/31/08 11:27 AM
05/31/08 11:27 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I used a set of 8 3/4 axles from a '69 Coronet 4 door in a '68 Charger housing in my other road runner. fit like a glove. maybe the rear in your Belvedere had been swapped in from an older car?
1981 Dodge D150 360 auto
Re: 8 3/4 Question [Re: basketcase] #66542
05/31/08 11:29 AM
05/31/08 11:29 AM
southern Idaho
southern Idaho
According to the guy I bought it from nothing had ever been changed.The car belonged to his grandfather.But anything is possible.Does anyone have the specs on these housings?
Re: 8 3/4 Question [Re: moparcyco] #66543
05/31/08 11:47 AM
05/31/08 11:47 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
perhaps the 4 doors are a 1/2 "narrower, but I wouldn't think so. I had always hear they were all the same, so I didn't bother measuring. I wouldn't think a 1/4" for each axel would be a problem. I ran my car for 5 years, drove it hard on ocassion, never had any problems.
Re: 8 3/4 Question [Re: basketcase] #66544
05/31/08 11:54 AM
05/31/08 11:54 AM
According to what I have read:
Std track first measurement
Spring seat center to center second measurement
A body 67-72 55.6 43.0
B body 62-70 59.2 44.0
E body 70-74 60.7 46.0
B body 71-74 62.0 47.3
B body 71-74 S/wag 63.4 47.3
I did not find flange to flange.
Are the perches the same? Have you tried to test fit the pumpkin & axles? I do not know the tolerances they could be ok.
Re: 8 3/4 Question #66545
05/31/08 12:00 PM
05/31/08 12:00 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 8 3/4 Question [Re: MoparforLife] #66546
05/31/08 12:11 PM
05/31/08 12:11 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Use this one... The other with the chart has some incorrect info in it.
http://www.moparts.org/Tech/Archive/axle/16.html
