Re: Just ordered my oil plate!!!
[Re: Moparnut426]
#665384
04/09/10 06:48 PM
04/09/10 06:48 PM
Posts: 7,506 Az
Crizila
Az
Cool! Never even knew they made one. My OEM plate, which is new, leaks a little - right on the header of course. Does the filter sit any farther out than with the stock plate?
Fastest 300
[Re: VernMotor]
#665386
04/09/10 09:14 PM
04/09/10 09:14 PM
Posts: 1,880 USA
Ron Silva
USA
I have it on a Magnum (R3) block. Fits good. Has not run yet so I cannot tell you if it leaks
SRT DEMON ONE SEAT
[Re: NITROUSN]
#665390
04/09/10 11:53 PM
04/09/10 11:53 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
For the most part a waste of money.
No. A waste of money would be ordering one , then digging into the water jacket while relieving the mis-matched drill bit paths in the bottom of the filter inlet bore. I also have the 5.00 threaded fitting that Canton doesn't supply. Anyone need them ? I have the block repaired thanks to Ryan J. and have converted to a remote filter , so this stuff will be a 50.00 paper weight unless I can sell or swap them.
