Re: Firm Feel or Manual steering
[Re: dd340]
#664572
04/08/10 07:16 PM
04/08/10 07:16 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I'm thinking of installing a steering quickener myself. I don't care for the over assist the factory has and I don't like manual steering either. The steering quickener will reduce the amount of assist to you as well as reduce the amount of turns lock to lock.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#664573
04/08/10 07:21 PM
04/08/10 07:21 PM
Posts: 21,808 Kirkland, Washington
Pacnorthcuda
I was hoping a fast ratio arm would have the desired side-effect of firming up the steering on my PS 'Cuda but the effect on the assist was negligible. Maybe a little. Still over assisted. I swear E-booger had a simple shadetree mod to the box to lessen assist but I don't remember the specifics.
[Re: dd340]
#664577
04/09/10 12:14 AM
04/09/10 12:14 AM
Posts: 7,759 So Cal
HealthServices
So Cal
Hotchkis has it on their E body and it works really well according to them. But I don't think we are suppose to know about this product since they do not sell it. I spoke to tech about it when they had open house once and he showed me it. Short of going to a rack and pinion, this is it. Every time I ask about it on the forum, they act like they have me on ‘ignore’ You have to cut the steering column and this is spliced into it, and reduces the amount of turns either 1.5 to 1 or 2.0 to 1 depending on which one you buy.
Allen
[Re: dd340]
#664579
04/09/10 06:34 AM
04/09/10 06:34 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
For my last two restorations I have rebuilt the steering box to firm feel in both PS systems. One was an a-body the other a b-body and I liked it a lot in both.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: BergmanAutoCraft]
#664583
09/06/10 01:35 AM
09/06/10 01:35 AM
Posts: 22,695 Bitopia
jcc
Bitopia
Not sure where this thread is headed. The ratio multipler box of 1.5 or 2.0 would in IMO make a power steering box WAY too fast, and on a manual box it would likely be WAY too hard to steer/turn under 30mph? without arms the size of the Roc (Not knowing front end weight/tire size makes that a guess). Additionally I can't believe the quickner box is really robust enough for daily driving/parking on a full size street car. IMO, Firm Feel stage 3
[Re: jcc]
#664584
09/06/10 02:01 AM
09/06/10 02:01 AM
Posts: 27,444 So Cal
autoxcuda
So Cal
I thought so too. But everyone that has driven that Hotchkis Emax Challenger loves it.
For some reason I having trouble with the math... 1.5:1 reduction on a 16:1 steering box is what resulting ratio??
10.667 or 12:1 or something else?
.. Additionally I can't believe the quickner box is really robust enough for daily driving/parking on a full size street car...
Circle track cars take a bunch of abuse. The toughness on a deal like that are the impacts on the gears. Like from potholes, curbs, etc. Well, on a circle track car they hit/brush walls at 90-100 mph.
The stock steering column bearings on our cars are nothing too HD or special. I think most of the load are at the box.
[Re: autoxcuda]
#664585
09/06/10 02:04 AM
09/06/10 02:04 AM
autoxcuda
So Cal
The problem with this quickner is that is requires quite a bit of fabrication and time. And it requires a core column. I talked with the guy who made it.
Here's some better pictures.
[Re: autoxcuda]
#664586
09/06/10 02:07 AM
09/06/10 02:07 AM
autoxcuda
So Cal
[Re: jcc]
#664589
09/06/10 11:30 AM
09/06/10 11:30 AM
autoxcuda
So Cal
I suspect the ratio is likely speed dependant, ie slow speeds a slow ratio, med speeds a fast ratio, and ala superspeedway/nascar speeds, they go back to a slow ratio to likely make more precise steering corrections and prevent oversteering, is my guess.
No, those multipliers are just straight gear reduction boxes. Nothing fancy with variable ratios.
On a 1.5:1 multiplier the input makes 1 revolution the output make 1.5 revolutions. Ok, thinking this word problem though...
So 2.0 turns of the steering wheel then into a 1.5:1 reducer box yields 3.0 turns of the steering shaft into the steering box.
Stock 16:1 power steering cars are 3.6 turns lock to lock.
So .4 turns at the steering wheel into a 1.5:1 reducer box yields .6 turns of the steering shaft into the steering box....
So additively, using a 1.5:1 gear reducer in line with the steering shaft with a 16:1 power steering box will give you 2.4 turns lock to lock at the steering wheel and yeilds 3.6 turns into the steering box.
I think the T/A fast ratio is 2.7 turns lock to lock.
I think I answered my own question.
[Re: jcc]
#664590
09/06/10 11:44 AM
09/06/10 11:44 AM
Posts: 1,481 Outside
thedriver
Outside
i put a manual box in my car, considerably more effort with the 16:1 flaming river box, but i doubt i ll regret that until im like really stinkin old. for now it works great. I dont miss throwin a p/s belt everynow and again at 6500rpm, less weight, one lesss thing to leak, car is now easier to work on. I've never looked back!
1973 challenger Dana. 4 speed. Low deck.
[Re: thedriver]
#664591
09/06/10 11:53 AM
09/06/10 11:53 AM
autoxcuda
So Cal
What size front tires do you have?
[Re: thedriver]
#664594
09/06/10 01:25 PM
09/06/10 01:25 PM
autoxcuda
So Cal
215/70/15.
The wider and more grippy the tire the harder it is to steer. 235/60 wide and lower profile 225 wide tires will be noticably harder to steer.
[Re: autoxcuda]
#664597
09/06/10 02:37 PM
09/06/10 02:37 PM
thedriver
Outside
215/70/15.
but honestly, the only time i notice "effort" in the wheel, is parking stall driving, as far as making corners, etc, there is no real effort there...plus you can really feeel where your tires are on the road.
[Re: RV2]
#664598
09/06/10 04:47 PM
09/06/10 04:47 PM
Posts: 727 Ottawa, ontario
dd340
Ottawa, ontario
Do you remember who the seller was and what did you have to pay for it?
As far a I know it was just someone selling a box they didn't want anymore. He also included the power to manual steering coupler. I won it for $225 and it only had a few miles on it. I thought it was a great deal in the end.
[Re: autoxcuda]
#664599
09/06/10 06:08 PM
09/06/10 06:08 PM
jcc
Bitopia
We obviously are on two different pages. Not sure how "variable" ratios got injected. However, it seems to me, that different ratios are favorable for different uses/speeds cars are driven, again slow ratio for superspeedways, fast for med speed track use, slow for around town street and parking. So you pick your poison, unless you can tell me about this variable ratio box for an old Mopar. Make sense?
[Re: jcc]
#664600
09/06/10 09:53 PM
09/06/10 09:53 PM
autoxcuda
So Cal
Ok, now I understand what you were saying.
I think the superspeedway and bonniville stuff will have a slower ratio. Even drag cars.
But if was power steering I don't see much of a downfall to quicker ratio for in the city driving.
I think a lot of new performance car have 12:1 or 10:1 steering ratios.
