Re: Fuel Pump eccentric spinning? [Re: plymguy] #66423
05/31/08 01:28 PM
05/31/08 01:28 PM
Snowing in the north!
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Re: Fuel Pump eccentric spinning? [Re: Dart 340] #66424
05/31/08 02:33 PM
05/31/08 02:33 PM
md
mopars4ever Offline
mopars4ever  Offline
md
That washer and key is toast. I would get a new washer and bolt and key from the dealer. No flat washer just the curved washer and bolt. Get the mopar performance kit P4529838 the washer is much stronger. I wouldn`t use a hardware store key. I`m pretty sure the key is hardened. Mike
Re: Fuel Pump eccentric spinning? [Re: mopars4ever] #66425
06/02/08 10:37 PM
06/02/08 10:37 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Thanks, I ordered the kit. Also getting a key. This guy has some messed up stuff. Thinking I should pull the oil pan and check the mains and rods too........
