Setting cold lash prior to break in. #663613
04/07/10 09:57 AM
04/07/10 09:57 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Look to be breaking in a solid flat tappet small block. Iron block and heads. Alum rockers if that matters.
What do I add or subtract to the card lash spec just to get this broken in???
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Setting cold lash prior to break in. [Re: CJK440] #663614
04/07/10 10:31 AM
04/07/10 10:31 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
I just set mine to what the cam card specified and didn't have any problems. I did check them after break-in and had to loosen them, though.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Setting cold lash prior to break in. [Re: bigsbigelow] #663615
04/07/10 10:35 AM
04/07/10 10:35 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Hughes said to loosen em up a bit to give a more relaxed break in like an extra .003 -.005.
call them ad ask em. i dont remember exactly what they said
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Setting cold lash prior to break in. [Re: aarcuda] #663616
04/07/10 11:07 AM
04/07/10 11:07 AM
Connecticut
5126brl No more Offline
Connecticut
With allum. heads I think it is to set them cold at -2 thousands so as the head heat up they will loosen up. On mine I just set them to spec cold on the dyno. Then re-adjusted after. I did not pull the inner springs and used GM E.O.S. No problems 4 years later. Good Luck
