Yoke and U joint #663532
04/07/10 07:07 AM
04/07/10 07:07 AM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
Should there be ANY side to side movement of the drive shaft and U joints in the Yoke on the Axle? I'm talking about 1/16" Or should it be bolted in without any movement at all?
Re: Yoke and U joint [Re: wtucker] #663533
04/07/10 07:11 AM
04/07/10 07:11 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
The u joint cap C clips should fit tight against the inner face of the yoke and there should be NO side to side movement. Any side to side movement of the joint in the yoke is wrong and it will not last long plus you will have a H of a vibration.
Re: Yoke and U joint [Re: MoparforLife] #663534
04/07/10 07:49 AM
04/07/10 07:49 AM
scratchnfotraction Offline
should be no side movement
what size u-joint and yoke?
make sure you have the correct size straps for the u-joint caps as well
Re: Yoke and U joint [Re: wtucker] #663535
04/07/10 07:58 AM
04/07/10 07:58 AM
Switzerland, Europe
Swiss_Robert Offline
Switzerland, Europe
I agree, there must be no play, nor sideways nor radial.
And it's not exactly "on the axle" or "bolted in". If you disassemble it you will find a cross with bearing caps on all ends.
After all these years having a 440 I realized that this means having an attitude... and a budget.
Re: Yoke and U joint [Re: wtucker] #663536
04/07/10 11:33 AM
04/07/10 11:33 AM
Locomotion Offline
Locomotion  Offline
If there is side movement when bolted in, either it worn or the yoke is spreading. Eventually it will pound out and break! That's why I went to a steel billet rear end yoke.
