Chassis cert? #663440
04/06/10 11:27 PM
04/06/10 11:27 PM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
The car I just bought is IHRA certified currently. I was wondering if NHRA uses the same specs for their certification?
Re: Chassis cert? [Re: 80arrow] #663441
04/06/10 11:36 PM
04/06/10 11:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I will say yes, mine certs the same for either
Re: Chassis cert? [Re: MR_P_BODY] #663442
04/07/10 07:10 AM
04/07/10 07:10 AM
8
80arrow Offline OP
80arrow  Offline OP
So if it passes IHRA it will pass NHRA?
Re: Chassis cert? [Re: 80arrow] #663443
04/07/10 07:13 AM
04/07/10 07:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Did on mine... I have both certs
Re: Chassis cert? [Re: MR_P_BODY] #663444
04/07/10 08:02 AM
04/07/10 08:02 AM
Fl. USA
PS Arrow Offline
PS Arrow  Offline
Fl. USA
I think you have to have both depending on if you are at an NHRA or IHRA track, correct?
Re: Chassis cert? [Re: PS Arrow] #663445
04/07/10 08:09 AM
04/07/10 08:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes... NHRA doesnt acknowledge the IHRA cert but I
was running mostly IHRA tracks so I got the IHRA cert
but then I started running NHRA tracks so I needed
their cert also.... check the tracks you will run
at to see what they accept
Re: Chassis cert? [Re: MR_P_BODY] #663446
04/07/10 09:06 AM
04/07/10 09:06 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Not usually a two way street. From what I have seen IHRA will accept NHRA chassis certs but NHRA will not accept IHRA certs
Re: Chassis cert? [Re: Bigcube] #663447
04/07/10 02:37 PM
04/07/10 02:37 PM
Lehigh Acres, Florida
rickstershemi Offline
IHRA will accept NHRA certs up to 150mph, beyond that you need an IHRA specific cert
Rickster
